Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Apr 30, 2012 | 02:39 AM
  #3331
TORETTO's Avatar
thanks for the info btw, and what size tire should I be looking for with the 9.5?
Old Apr 30, 2012 | 02:57 AM
  #3332
DrewDrew's Avatar
whoops. I'm tired from work. yea, an inch is 25mm. so you should be fine with a 25mm spacer.
I'd get a 225/40 for the 9.5, since you're on 18s, right?
Old Apr 30, 2012 | 03:01 AM
  #3333
TORETTO's Avatar
yeah im on teeny weeny 18s. im assuming the 25mm would poke out just like 1mm?
sounds yummy.
Old Apr 30, 2012 | 03:05 AM
  #3334
DrewDrew's Avatar
if that. it would virtually just look flush being that close to poke/no poke. I'll just say it'll look much better than it currently is.
Old Apr 30, 2012 | 03:58 AM
  #3335
TORETTO's Avatar
hmm. do you think it will look off in comparison to the rears?
Old Apr 30, 2012 | 08:18 AM
  #3336
05 sedan's Avatar
Originally Posted by 05 sedan
I have some volk sf challenge Front 19x8.5 +34 offset and Rear 19x9.5 +36 the tires i have on now are Front 245/35/19 rear 255/40/19 but i don't like the way they look I am lowered on eibach prokit but will be in coilovers in 2 weeks. I like the stretch tire look but not sure what sizes would be good with out going extreme. Any help would be good thanks
any comnments
Old Apr 30, 2012 | 10:59 AM
  #3337
DrewDrew's Avatar
yea. for sure. what's the rear specs again? then I can tell you how much more you'd need for it to start looking proper.
Old Apr 30, 2012 | 04:13 PM
  #3338
hawaii's Avatar
Hey guys, its time for some new tires. I have an 04 sedan with coupe 19's and tein flex's. What sizes do you guys recommend?
Old Apr 30, 2012 | 05:39 PM
  #3339
TORETTO's Avatar
18x13 -6
295/35/18
Old May 1, 2012 | 01:53 AM
  #3340
DrewDrew's Avatar
if you eventually want the same camber/will have the same natural camber in the future, you'll essentially want a 12 -8 up front, but idk if 12s fit up front. when you rebarrel, you can turn it into a 11.5 +1, then add a 15mm spacer to make it equivlant to a 12 -8, and run a 255 or larger run 245 on it. (fyi, if you rebarrelled to a 12, it would have an et of -5)
whatever you choose to do, you'll start looking much better after you rebarrel to a 10.5 +13 or 11.5 +1 up front, regardless of use of spacers.
there's just so many options when it comes to rebarrelling/spacers/addition of camber kits.
Old May 1, 2012 | 04:20 AM
  #3341
Drew113's Avatar
Ban Hammer Expert
^^i don't understand anything about rebarrelling at all....i wish to be educated Drew
Old May 1, 2012 | 04:36 AM
  #3342
DrewDrew's Avatar
basic math, lol. for every .5" of lip you add, you add 6mm to the offset. but you gotta remember it becomes 12mm more aggressive overall. (half inch is ~12mm. 6mm is applied to the inside and outside lip, hence the 6mm offset adjustment). for example. 9.5 +17, a standard gt-s set up. if I rebarrel to 10", my offset is +12, but 10 +12 is 12mm more aggressive than 9.5 +17.
at least I hope it's like that. LOL. that's how L-Fab explained it to me when I wanted to rebarrel my gt-s to 20" steps. Blain, is what I said correct? make sure before I completely FUBAR somebodys wheels.
Old May 1, 2012 | 04:38 AM
  #3343
TORETTO's Avatar
http://www.1010tires.com/wheeloffsetcalculator.asp
Type in 10.5 , +17 in the first two
And 11 , +11 (since you subtract 6mm right?)
The outcome is that it extends 12mm outward more.
If this calculator is correct.
Old May 1, 2012 | 04:42 AM
  #3344
DrewDrew's Avatar
Correct. As I said. I slightly reworded it. Hopefully it makes sense now. I'm tired.
Edit: In the case you want to find the same aggressiveness in a wider wheel, obviously do the opposite and add 6mm/.5" added to the offset. 9.5 +17 = 10 +24.
Old May 1, 2012 | 04:43 AM
  #3345
TORETTO's Avatar
i'll see you in bed
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
