Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
Old Aug 6, 2011 | 05:37 PM
  #526
Wrathernaut's Avatar
Gentle Manne of Leisure
^ Just connect it to the accessory wire (RED) for the radio.
Old Aug 6, 2011 | 05:49 PM
  #527
shocker611's Avatar
so the read coming out of the PAC? Like the ignition wire? Also I think my friend must have just blown a fuse or something because he was trying to get it to work and now it wont turn on at all... Any idea of what might have been blown and how it would have happened? Im seriously about to just break the damn thing
Old Aug 6, 2011 | 05:52 PM
  #528
Yes, the red coming out of the PAC ROEM.
This is why you disconnect the battery when you work on the electrical system.
Anyway, there's a fuse box in the driver's kick panel, and _two_ in the battery compartment, test & replace as necessary.
Old Aug 6, 2011 | 06:11 PM
  #529
shocker611's Avatar
Yeah I already tried the red ignition line before and couldn't get it to work but thanks for the help on the fuses
Old Aug 6, 2011 | 10:05 PM
  #530
Trickstyle's Avatar
Originally Posted by shocker611
where the hell does my amp turn-on wire (blue/white) hook up to? My sub isnt turning on and I am getting really low sound like the guy above me was having.
yeah, like wrath said, the red should do... you just need an ignition switched 12v signal. but now im thinking maybe its not your remote line, maybe its your amp's ground or +12v... that would explain the amp not working(hence the extremely low signal flowing through it). worst case scenario, you find the +12v and the ground and run your own
Edit: another thing you should do is go in your trunk down to the left of your spare tire(the plastic molding will pop out) and check if your amp's harness SOMEHOW came loose. and if ALL else fails, i guess u got a blown amp and part of me would think that the amp would be fused... idk, ima look more into it
Old Aug 6, 2011 | 10:09 PM
  #531
shocker611's Avatar
See but the one reason I ruled that out was because I had it hooked up to the stock system and it worked fine.. also im not sure if it is the way its supposed to be but after I plug everything in I still have two of the white wire harnesses leftover unused. Am I missing something?
Old Aug 6, 2011 | 10:39 PM
  #532
This really is something that is a major PITA to try and diagnose when all we have is your word to go on that everything's hooked up right and such. Completely disassemble the wiring harness to the PAC REOM, take it to somebody who's good at this stuff, and have them re-wire it for you, as it's probably something simple you missed, but you'll overlook it every time you look at it.
Old Aug 6, 2011 | 10:50 PM
  #533
shocker611's Avatar
Yeah you're probably right.. ill take some pictures tomorrow just to show how the amp was wired up because it's a little different but ill go ahead and concede defeat and take it in for pro instillation??
Old Aug 6, 2011 | 10:51 PM
  #534
shocker611's Avatar
Old Aug 7, 2011 | 03:10 AM
  #535
Trickstyle's Avatar
well if your in SoCal i would be happy to help u
Old Aug 7, 2011 | 04:37 AM
  #536
shocker611's Avatar
Thanks a lot man but unfortunately im in utah.. and I dont have good connections here for car stereo
Old Aug 7, 2011 | 05:14 AM
  #537
Trickstyle's Avatar
ahh no bueno :/ well gl!
Old Aug 7, 2011 | 03:55 PM
  #538
shocker611's Avatar
alright well heres a link to the way that they hooked it up. They pretty much used an rca to wire converted then spliced the wires. I know its kind of hard to see. Also you can see the two boxes that didn't have a spot to hook up to
http://i294.photobucket.com/albums/m...-36-55_758.jpg
Old Aug 7, 2011 | 03:56 PM
  #539
shocker611's Avatar
http://i294.photobucket.com/albums/m...-37-13_329.jpg
Old Aug 7, 2011 | 03:57 PM
  #540
shocker611's Avatar
You have already rated this thread Rating: Thread Rating: 31 votes, 5.00 average.
