Wrathernaut's Double-Din Installation FAQ, Shopping and Resource List
Old Apr 2, 2012 | 12:45 AM
  #826
Wrathernaut's Avatar
Gentle Manne of Leisure
Aftermarket radios don't pump power to the antenna amp via the "power antenna" wire. Hook the power antenna wire up to the cigarette lighter's power wire, or the radio's switched (red) power wire to get your radio up.
Sorry, I dont' have a wiring guide out here with me to tell you the exact wires to use for the bypass at the amp.
Old Apr 2, 2012 | 09:46 AM
  #827
Trickstyle's Avatar
Originally Posted by yarko
I know I'm a pain. Lol. But, I need a quick hand. I installed my kenwood double din. I installed it and hooked by power antenna to the baby blue on the kenwood. When I installed it in the car and went to run my rca's and amp turn on wire I didn't have the blue wire free on kenwood. So....I second guessed myself and I disconnected the power antenna from the baby blue (my kenwood never actually had a solid dark blue that I'm used to hooking the amp turn on to). I hooked the amp turn on to the baby blue and installed the deck. BUT..now I have zero radio reception. So, do I have to hook that power antenna back to the blue..and do I hook the amp turn on wire to it as well? PART 2 of my question is..I used the metra 550 harness (non bose harness) because I don't plan on using the bose amp at all. I as of now have no sound..and I knew I wouldn't. Does anyone have a detailed description on taking the bose amp harness and connecting the input side to the output side so my speaker wires and connected and running thru my kenwood? Thanks guys!! I really do appreciate the help
if im not mistaken, that "power antenna" lead is for motorized antennas, so you turn the radio on, the antenna raises, you turn it off, it lowers. mine is disconnected and I get perfect radio reception. All you should need is the antenna adapter. you can get one off crutchfield for like $15-$20 i think or you can go to wal mart like I did and grab a universal one for like $5. i really dont listen to the radio so radio quality isnt a big concern of mine.
Old Apr 2, 2012 | 10:06 AM
  #828
Our cars utilize an antenna amplifier to make up for the fact that the antenna is just a wire in the rear window. Power antennas usually have their own power wire and just use a signal from the radio to switch on and off. Our amp uses more power than the signal sent by radio needs, that's why so many people run into reception issues when using an aftermarket radio - not enough juice going to the amp. That's why I recommend using an actual POWER - not 12v signal - wire going to the antenna amp.
Old Apr 2, 2012 | 10:09 AM
  #829
Trickstyle's Avatar
good to know, thanks!
Old Apr 3, 2012 | 08:53 PM
  #830
yarko's Avatar
I got it all figured out guys. Amp is bypassed, speakers are all working. Everything is as it should be. Thanks for all the help everyone. Now....what kind of fiberglass sub box should I build. Lol.
Old Apr 4, 2012 | 01:04 AM
  #831
Ported.
Old Apr 8, 2012 | 05:50 PM
  #832
FastSTI's Avatar
Has anyone with a 03-04 coupe had any problems using Metra 70-7551 w/ bose amp?
Old Apr 9, 2012 | 12:43 AM
  #833
Yes. A great number. That's why I do not recommend it when keeping the bose amp. It's worked for some, but the gamble of frustration and extra labor involved (especially if you're paying for the labor) if you don't get lucky and have it work isn't worth the $30 more that the ROEM-NIS2 costs over the 70-7551.
Old Apr 11, 2012 | 09:13 PM
  #834
FastSTI's Avatar
had my pioneer avh 4400bh installed today with the metra 70-7551 harness and its working flawless!!. sounds better then my factory unit for some reason.
Old Apr 12, 2012 | 01:24 AM
  #835
Well, you're one of the lucky ones. Mine worked fine too, but there's been far too many who can't even get it to work with professional installation that I really don't recommend gambling on the trouble it is if the 70-7551 doesn't work, just to save $30.
Old Apr 12, 2012 | 02:33 AM
  #836
FastSTI's Avatar
Yes i totally agree. Only reason I didnt get the pac is because they didnt have one in stock. they told me if the 7551 didnt work they would order in the one you suggested at the same price. but im glad the 7551 worked out fine for me.
Old Apr 12, 2012 | 01:11 PM
  #837
cainon01's Avatar
so are you saying to hook the power antenna wire from the pac harness to power and that will give my antenna the power it needs? thanks
Old Apr 12, 2012 | 02:01 PM
  #838
cainon01's Avatar
thank heavens i followed wrathernauts list to a tee. the trim ring that came with my pioneer doesnt fit it!!!! Glad i got the scosche.. Shame on you pioneer! Thanks wrathernaut
Old Apr 12, 2012 | 05:38 PM
  #839
Techre5's Avatar
This is suck a sick well done guide, I have referenced it tons of times
Old Apr 13, 2012 | 02:55 AM
  #840
Correct.
You can try with the signal wire from the harness, and if the radio reception sucks, change it later, but I'd just say go for a power wire over the signal wire from the get-go.
You have already rated this thread Rating: Thread Rating: 31 votes, 5.00 average.
