TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Infiniti Rev-Up Oil Consumption TSB
Old Dec 8, 2010 | 02:17 AM
  #1381
V35 Skyline GT's Avatar
6MT Coupe
Originally Posted by VQdriver
How much oil does the replacement consume? This is awesome...just awesome lol.
Usually within the 'ok' on TSB OC chart like mine has been and still is, but have read some still in 'no good' and on their second/third replacement (mostly on the my350z OC thread). However, that's all based on the longblock replacements of past.
In a sense, a new chapter has started with the latest revised shortblock only TSB. It'll be interesting to start hearing reports on those shortblocks and how they fair with the OC issue.
Old Dec 8, 2010 | 05:51 PM
  #1382
The_Scooch's Avatar
I waited until my '06 had 50K on it and then took it in for the tests, etc. I knew it would fail so a new engine at 50K is nice. 3 weeks later and I now have a new shortblock. It's too early to tell but I'll be watching the consumption and will report in when the results become evident. The service manager's comment to me was "Nissan finally figured this out and realized the problem did not include the heads and etc.".
Should be interesting. It sure runs nice.
Old Dec 11, 2010 | 01:16 AM
  #1383
Flipjnh's Avatar
Thanks, good thread
Old Dec 12, 2010 | 01:48 AM
  #1384
Skaterbasist's Avatar
Retired SuperMod
Does anyone know a direct phone line/email to contact CORPORATE regarding the oil consumption issue? I'm already working with my dealership but I can already tell that the dealer is trying to BS me. I want to be prepared just in case.
Old Dec 12, 2010 | 12:59 PM
  #1385
6MT Coupe
^I only know the customer care number, but get a file/case number when you first do talk with them regardless. It will help with (if necessary) future correspondences and if your building a case against Infiniti with the BBB or your Attorney for example (if it gets that stupid).
Asking for file/case number also sends a message that you're savy and mean business with Infiniti about this OC issue
Old Dec 12, 2010 | 07:22 PM
  #1386
allanmaxt's Avatar
does your car have to be under warranty for this test ?
Old Dec 12, 2010 | 08:46 PM
  #1387
Hammerhead i-Eagle Thrust's Avatar
if you don't mind paying for the engine I'm sure they will test if for you...
its a TSB, not a recall.
how much are you burning? if its 1 qt per 1000 miles or less, I would just add the oil and not worry about it unless it gets worse
Old Dec 12, 2010 | 09:50 PM
  #1388
rickyrch's Avatar
I have a question, maybe it has already been answered. everytime at night when the headlights are on, i can see smoke coming out from the hood. the car runs smooth, it does not heat up, there is no unusual engine noise, so does the smoke mean the G is burning oil??
Old Dec 12, 2010 | 09:53 PM
  #1389
um check the oil...................you should be doing that at least once a month if not once every 2 weeks and before any long trip
Old Dec 12, 2010 | 09:58 PM
  #1390
rickyrch's Avatar
yea i have been checking it but i still dont know what is causing that smoke
Old Dec 13, 2010 | 02:06 AM
  #1391
6MT Coupe
^Smoke under hood = external oil leak.
Old Dec 13, 2010 | 02:27 AM
  #1392
not if he has all of his oil................
Old Dec 13, 2010 | 04:25 PM
  #1393
yglide115's Avatar
looks like the only thing holding me back from my new engine is my lack of oil change records... i change my own f'n oil... ugh.
Old Dec 14, 2010 | 12:56 AM
  #1394
wiz2's Avatar
Planning on another oil change this week for this issue. Siince the last change it burned off all 5 qts in less than 1500 miles. Engine noise and teh oil light let me know it was burning oil faster than the last oil change and I was forced to put 3 qts of oil in it being a couple of hours from home. I think the steps needed to prove that there is a known problem is kind of silly. How come there arent any class actions suits for this?? I dont feel the dealership has tried to really scam me yet,but listening to others it sounds like the scamming and games are random. This is similar to the 1MZFE sludge motors Toyota had. Blame the consumer for poor mintenance as long as possible until legal action. But they had much larger exposure due to the number of units sold.
Old Dec 14, 2010 | 12:45 PM
  #1395
G2FLIP4's Avatar
everything
Cant believe you guys are getting screwed so bad by the dealers. I went in and had my engine ordered right after i failed. Didnt need any paperwork showing oil changes. I told them it was burning oil, did their test, failed, they said ok and ordered the new motor the next morning.
Quit letting them pull their BS! Print out the TSB and ask them where it says all this BS they keep spewing to you guys!
Dropping my car off tomorrow afternoon so they can start the block replacement.
You have already rated this thread Rating: Thread Rating: 4 votes, 3.75 average.
