G35 & G37, Coupes & Sedans
Old Jun 5, 2020 | 05:35 PM
  #10261
eazdaskeez's Avatar
Yeah I hate taking the compressor out lol. I'm pretty good with the spray cans and spraymax 2k sprays very smooth if you are used to spray cans
Old Jun 5, 2020 | 07:15 PM
  #10262
LoSt180's Avatar
Originally Posted by cswlightning
Pulled the front suspension apart chasing a clunk and found that the ball joint on the Mevotech Supreme compression rod I installed 45k miles ago had lots of play. Ordered two new Moog compression arms to replace it and the Mevotech on the other side that's now due to fail within the next 10k miles....
yeah, don't think I'll order Mevotech arms again either. Might have gotten 60-80k out of those compression rods, end links were sloppy also. Went with ACDELCO and Moog this time around when I redid the front suspension, again.
Those Spraymax 2k cans are money. Good for bumpers, not so smooth on a hood I did tho.
Old Jun 6, 2020 | 12:31 AM
  #10263
Yinster's Avatar
5 Year Member
Finally got my 3.7 vlsd on my g, its sure not fun
Btw, my slip light just constantly on after the swap, i have already disconnect the battery for the night..... any idea or potential solution to solve it ( if not i will just do a vdc delete lol)
Old Jun 6, 2020 | 02:57 AM
  #10264
858G's Avatar
sedan
Those headlights came out nice, what grit did you sand with before clear?
Old Jun 6, 2020 | 07:02 AM
  #10265
eazdaskeez's Avatar
I just used a red scuff pad, I believe the red pads are 400 grit.
Old Jun 6, 2020 | 11:15 AM
  #10266
LoSt180's Avatar
Make sure you didn't screw up the ABS sensors on the back of the diff, or forget to plug them in.
Old Jun 6, 2020 | 05:21 PM
  #10267
eazdaskeez's Avatar
Bumper and headlights back on. Now to get it off jackstands after I replace the axle in the am
Old Jun 6, 2020 | 08:15 PM
  #10268
Yinster's Avatar
5 Year Member
i did plug em back and i ever purchase a sensor off a parts 350z with VLSD..... my slip light still flashing like crazy once i hit 40mph....
Old Jun 7, 2020 | 11:54 AM
  #10269
cswlightning's Avatar
so you don't like the 3.7 ratio? Or just the warning lights? What are your performance impressions compared to the 3.5?
Old Jun 7, 2020 | 06:52 PM
  #10270
Yinster's Avatar
5 Year Member
its not a fun process the install/swap the pumpkin. and i just hated it after all the hard work i have issue with VDC/ slip light..... it literaly wont let ur car pass 40 mph.... so far i have to drive with my vdc off
Acceleration for 3.7 is amazing compre to 3.3, mine g is an auto with open diff.... never driven a 3.5 ratio yet
Old Jun 8, 2020 | 09:37 AM
  #10271
LoSt180's Avatar
oh, you have an auto? Those behave, differently. In the gear swap thread, someone mentioned their speedo was off. Seems to indicate the rpm sensor in the auto trans is used more than officially documented.
I would hook up a scan tool and monitor what codes are there and see if you can see wheel speed on all 4 corners.
Old Jun 8, 2020 | 06:34 PM
  #10272
Yinster's Avatar
5 Year Member
i do have a obd2 scanner and no SES light on my car either.... i think i might do a scan tool test soon, i mean i understand the speedo will be off..... but the slip issue is just odd and on that g35s swap thread, someone did mention the issues will seems eventually fixed itself lol
Old Jun 10, 2020 | 10:21 AM
  #10273
If it takes the nitrous and doesn't blow up, it deserves some bodywork. Otherwise....
Ordered a fuel pressure safety switch, jets for 55-100 shot, and an RPM window switch. Need to figure out if it's possible to tap a fuel line or something cheap before I order a $75 fuel port adapter.
Planned some dyno time with Pat at Limp Mode Tuning in Portland Maine. Guess we'll see how she does at 153k and 1qt/1000 miles both NA and with a 75 shot, no ECU tune.
Old Jun 10, 2020 | 11:15 AM
  #10274
eazdaskeez's Avatar
Washed it
Old Jun 13, 2020 | 11:41 PM
  #10275
Yinster's Avatar
5 Year Member
Didnt drive my car much even after diff swap, decide to recreate some of that Need for speed vibe since im too bored at home
