- Will Spyder Headlights work with my G35?
- Headlight LED Strip Question
- How are side-markers Mounted?
- Leaking rear lights, tail light seal?
- where to tap into dome lights
- Headlight Mod Question
- accent lighting
- Phillips Vision 921 Backup Lights in 07 G35 Sedan
- HID lighting issues
- What bulbs to use??? 04 sedan
- Driver's Headlight went out and makes strange noise
- Lenses for 06 lights
- Why does my HID light go out when warm outside?
- HID light, bad ballast or igniter?
- Question about my H1 fog lights.
- Top parts of the headlights (D2R bulbs) not working...
- Do fx35 projectors drop in
- airbag light blinking
- Lighting Help H1 HID conversion
- V35 Coupe tail light
- 2006 CANADA projector upgrade from '05
- 03 g35 sedan FOGS???
- Fixing Projector Headlight Lens "Inside"
- Help: Back-Up Lamp Switch
- Clear bulbs for clear corners suggestions?
- Clear Corner No-Bump Options? + LED Questions
- What will fit my '04 sedan
- parking lights not flashing
- for those of you that have opened up 06 coupe tails
- How to disable DRLs
- where can i get quality led bulbs for reverse lights?
- need to find a headlight lens or way to restore it
- Tail as you turn module
- OEM to Aftermarket Swap: Taillights Help?!?!
- Purchasing headlight asseblies to replace stock HID's
- Halo Kit
- Halo kit on halogens?
- Tail lights keep turning off
- Passenger side low beam light, side marker light, and seat warmer light not working.
- 07 g35 coupe turn signal socket type
- Jdm clock wiring
- Right Turn Signal and Hazards Not Working on '06 G35 Sedan
- OEM HID Headlamp Bulb - 03 G35
- Can Anyone Recommend A Quality Interior LED Kit for V35 Coupe?
- 08 G35 speedo and clock led
- Switchbacks - 06/07 Projector
- Black Housed + LED Headlights
- WTF! 05" 6mt HIDS to 06" Projectors
- Dome light
- 03 retrofit
- 03 coupe turn sigal / orange lens size???
- g35 clock light led replacement
- Is this guy screwing me...?
- iJDMToy Review-Bad Customer Service
- 06 projecters noob questions. ..
- Brightest reverse lights
- headlight damage
- 07 sedan srivers side headlight WITH tech
- Front Turn Sig Help Anyone?
- vLED v3 triton
- Replacement lens for headlights?
- 04 Coupe City Lights
- What do you think about these lights?
- Have Factory HIDs - Want New NON HID Housing - Switch to Aftermarket Bulb - Possible?
- seemingly basic question regarding wiring
- 2003 Infiniti G35 Sedan Headlight Bulbs
- 2008 G35x Custom Halo Light DRL Problems
- can i swap headlite lenses,ebay to oem????
- 03 sedan hid for fog lite question???
- OEM Cluster LEDs
- Help With Aftermarket Headlights
- 06 sedan quad projector retrofit
- Halo wiring where best to tap for power?
- need new headlight(really only lens) for 07 sedan w/ tech
- Headlight replacement, what years fit?
- Modify 04 g35 coupe headlights??
- DIY - super bright LED trunk lights
- Smoked My Tails, Now I Need Brighter Lights
- Independent foglight module
- 03 G35 Headlight replacement
- Haven't been on the forum in a while. Have some questions about lights.
- 03-05 headlight wiring info help needed...
- Need Tail lights customized, anyone?
- Front bumper corner lights with LEDs. Need help!
- 2003 Sedan Retrofit Help
- Any custom headlight builds? I need suggestions
- 2006 Sedan headlights not working? both out same time - flicker
- DIY 03-04 Vanity Light Upgrade
- 06-07 projector clearance strip?
- impul front fog housings?
- H1 HID Kit questions
- 2007 g35 interior lights don't work
- DRL always on...
- Polish & Seal G35 Headlights or Tail Lights - Opti Lens
- Window lock bulb
- Possibly headlight ballast
- led question
- Halo kits.
- G35 sedan headlight oem hid issue
- my brake lights stay on at all times?
