- Headlights flickering on/off while car is off? Haunted car 0_o
- Lights keep going out!
- 06 projector fog light mount MISSING!!!
- Sealing HID Ballast
- Lighting question
- loose side marker
- '06 Projector/Fog HIDS Questions
- G35 Headlight Mod
- Install help needed
- Passanger Side Corner Light is Out
- HIDs in Fogs causing Eyelids - solution
- Illuminating the turn signal LEDS to look like the G37 tails.
- 06 G35 Couple foglight to HID
- Installing fog lights on the G?
- Bent the metal prongs holding D2S bulb
- any one got clear corners for sale?
- H1 Bulb question
- Getting Moisture Out
- Who has the best deals on Clear Corners???
- Righ side headlight cutting out
- Orange Turn Signals - Options?
- Projector Headlights, any vendor on here do them?
- HID bulbs
- taillight schematic
- HID Lights on '06 coupe help/question
- LED Speedometer Conversion
- Help Determining What Lights To Get Installed?
- Quick question
- DDM Tuning replacement bulbs?
- need help replacing key ring light
- aftermarket fogs
- help auto lights not working!!
- HID Ballasts and Bulbs
- Corner lights don't work after projector install
- license plate and door bottom leds
- Quick HID question
- Help a Noob Out? First Car...
- Painted and Modded Headlights opinions...
- Right Front Head Lights On and Off
- rear tail light wiring diagram???
- Noobie question.
- D2S HID Bulbs
- Fog lights
- white led lights
- 06 projectors not plug an play?!
- parking lamp fuse keeps blowing
- New detailed heated seat led mod write up
- HID off, clearance bulb on
- headlight mod issue causing dash light issue?
- Fog light adjustment
- blacked out/clearcoated headlights.. looks good but bad night vision
- Amber Clearance (LED or Wedge) pics?
- Amber Clearance Strip (pics?)
- Oracle Halo Kit Question
- Need help changing headlights
- Led dome lights help?
- Headlight led DIY
- Headlight question
- How much would labor/paint on these headlights cost?
- Help HID Kit installation
- auto On/off headlights
- side mirror blinkers
- how to change the rear license plate lights
- 2003 Headlight Help!!
- Headlight Painting
- 50w bulb with a 35w ballast?
- Need help with headlights please.
- Headlight Housing Round LED's
- just how much is a headlight?
- Headlight shopping!! Suggestions??
- HID fog/High too hot?
- Upgraded my headlights to 6K and now im having issues...
- Dome light
- G37 Projector shroud in a G35 headlight
- Clear Corner BUMP
- HID in the foglights ?????
- 04 passenger headlight
- HID flicker
- Check out these lights
- New Aftermarket headlights?
- Wierd HID headlight problem......
- All Interior Lights Not Working
- Replacement light-heated seat button
- Clear corner LEDS
- Fogging in headlights?
- what HID headlights bulbs are illegal?
- light went out
- hid's installed on fog/high beams problem...
- 05 G35 coupe
- 03-05 coupe ballast issues
- Side marker/clear corner with LED Bulb pics
- Halogen on a 2007 G35? Possible??
- SxExCx: New headlights...New idea
- Replacing my 04 coupe headlamps with 06 +
- air vent lights
- Bad BCM map light problem need technical help
- Footwell lighting DIY
- DIY Projector Retro Fit
- DIY “Iron Man Halo” LED projector
- '06 sedan headlight bulb question?
