View Full Version : Brakes & Suspension
- Metal is coming through my tires and i think it has to do with the suspension
- St Suspension
- Clunk/Clicking Sound from Front Right Wheel
- Floaty, sagging Suspension and Hard brakes?
- Pic Request: HKS Hipermax IV GT
- compression rod bushings tool?
- Suspension Upgrade. Coilover or Spring/Shock?
- 03 coupe, what shocks struts
- Need some rotor recommendations...
- Squeaking/creaking noise from front end?
- PLEASE HELP! Braking problems
- 04 coupe suspension
- Overheating drivers rear??
- Poly bushings theory!
- Front Suspension Install
- Suspension Squeaking Concern
- Sway bar end links replacement - position of "bracket" critical?
- While replacing Struts/ Shocks.. what else to do?
- Replacing only the strut in a coilover set
- Upper Control Arm Bushing Replacement Question**
- Z1 Motorsports FUCA ??
- Track pack Brembo's on G35X
- Lower Translink Replacement
- HELP! 06 6mt coupe SPC rear camber issues
- Energy compression rod bushings -- sedan v coupe
- rear shocks
- front end clunk blues
- Best ride quality coilover for coupe with Kuruma Z bumper...possibly Tanabe Pro 5?
- Going back to near-OEM ride quality?
- Clunk in front suspension when reversing.
- 2003 6MT coupe on 350z Bilstein/Pro-Kit
- steering wheel and front end vibration after tein stech springs installed
- Tire rubbing!
- premature failure in rear swaybar end-links?
- Bushings not covered under extended warranty?
- Slip abs and vdc and speedo not working
- 05 G35 Allignment / Camber kit Help please *
- BC Racing Coilovers with 8k/8k, 7k/7k, or 8k/6k springs?
- Toe issue
- 05 6sp Front Camber Arm Advice needed.
- brake problem help needed fast
- Caliper Color Decisions
- Changed rotors/pads/fluid, brakes feel weak
- Rebuilding HKS Coils (SoCal Area)
- Part number?
- ABS Wheel Sensor - VDC, Slip, ABS light
- Cleaning coilovers...
- rear shock bushing new kit HELP
- SPC Rear camber arms with oem toe bolts?
- Alignment for slammed G's in Pensacola area?
- Replaced control arms, car now pulling
- Coupe guys with D2 coilovers
- 2005 G35 SPC Adjustable Control Arms Ball Joints
- Stillen Rear Sway Bar (RWD Q50s)
- Stoptech pads and rotors
- Sticking Caliper Issue
- What do I need to drop my G?
- How do I fix a body roll issue?
- New Coilovers, too bouncy
- 2007 g35x strut mount bearing problem
- Best coil overs for 2003 g35
- OEM Fender to Ground Measurements
- G35 spring rates
- Flat tire sensation, with no flat tire
- G35 Sport Struts
- anyone have issues with powerslot rotors?
- Replacing Shocks and Bushings Question
- G35 to g37 akebono conversion
- Reman Calipers - Which Ones on 2006 G35X
- Anyone have one of these installed? GTSPEC chassis brace
- 'Mo Research on Rotors - G4000 vs G3000
- replacing upper control arms question!
- Simple question on rims
- Zerk locations / Chassis Lube points / how many are there?
- HELP Please! Torque Specs Needed
- Has anyone seen these new front upper arms?
- Cryo Treated Rotors - Science or Snake Oil
- Need a Brake Kit - Very Little Idea of What I Need, Nub Alert
- Bushing Help
- G35 Coupe Suspension Replacement
- Squeak after G35 strut replacement
- 2003 G35 Sedan Swift Springs/ KYB Shock Combo
- Anyone else have it THIS severe?
- What is this piece?
- BC's getting bad rep?
- Why do my Brembo's suck?!?
- Squeaky noise on driver side.
- Need brakes suggestions - 06x
- '04 and '05 coupe knuckle part numbers - 40014AL550 and 40014AL55J
- Should I replace my Suspension?
- 2008 G35x Knocking Noise at Highway Speeds
- G35X 2005 AT 2 questions about suspension and brakes
- Grinding noise on cold start (felt in brake pedal)
- So broke that gromet that turns the brake lights off
- Belistin adjustable suspension 03-06 g35
- Curious how shops adjust toe (03 sedan)
- G35 Sedan Spindle Knuckle Assembly
- Caliper Bracket Bolts Questions
- Air suspension SCUBA setup
- Hit curb. Steering wheel tilting slightly right and vibrates at highway speeds
