PDA
View Full Version : Brakes & Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110
  1. what would be the best damping rate for HKS coilover?
  2. Alignment shims
  3. anyone put air shocks on the rear only? Sedan
  4. Espelir Springs?
  5. How can I check coilover to see if it needs to be overhauled??
  6. New rotors too large?
  7. base coupe to nismo 350z setup
  8. 350z or 07+ G35S Sway bars?
  9. Suspension Problem?
  10. Clicking noise from front driver side...
  11. Need alignment specs for a lowered g sedan
  12. coilover setting please!
  13. 05 Sedan - brake issue...soft to firm??
  14. Do the RSR 350Z springs need the rear spring mount mod ?
  15. anyone know about HKS HYPERMAX LS+ ??
  16. Sway bars......REALLY??
  17. G35 and handling
  18. 03 G35 Sedan w/ sport susp - looking for replacement struts
  19. Quick Question Regarding Sliding Pin Bolt Size
  20. Question/Issue replacing front brake pads
  21. Brake kit recommendation...
  22. Anyone running the Momentum Performance Front A-Arms?
  23. Godspeed front A-Arms???
  24. Which will blow new Tokico shocks faster??
  25. Squealing Brakes on my '07' G35
  26. Need Spring Advice( read the sticky)
  27. Help Tokico HPs dont fit sedan w/ sport susp?
  28. pasenger side vibration at highway speed and braking
  29. The time has come. Need a camber kit.
  30. While I'm at work, FIgure I could ask
  31. Wheel Studs
  32. 05 coupe front brake HELP
  33. alignment questions
  34. New Whiteline compression rod bushings
  35. I put in a fuse for HICAS.
  36. Compression Rod / bushing replacement part numbers
  37. Strange ABS problem
  38. toe bolt template
  39. 06 z springs on 05 g sedan shocks/struts = ?
  40. Slotted Rotors any good for our cars? Which Brand?
  41. Best mount for Tokico HP struts on '06 G35 sedan?
  42. Anyone tried gravity brake bleeding?
  43. ams brake pad
  44. Looking to lower my sedan..need advice
  45. Collar removal? Picture included.
  46. Painted my calipers
  47. Help me G-driver, you are my only hope. BC coil adjustment
  48. anyone used Autozone brake pads or the simple pads for rear?
  49. Which brake fluid for 04 coupe brembos?
  50. Brake Questions
  51. Hawks HPS or StopTech pads?
  52. Stock Journey (non sport) Struts with Eibach Pro-Kit
  53. anyone experienced problems with the bushings? G35 coupe
  54. What affects camber?
  55. Need to replace 350z suspension
  56. brembo swap
  57. hitting arm on bumps?
  58. uneven tire wear toe bolts ?
  59. installing LCA bushing
  60. Mixing springs
  61. brake pad suggestions.
  62. Bilstein PSS10 or HKS III or Tein CS for comfort?
  63. 05 sport sedan springs noticeably thicker than zs
  64. KW coilovers not low enough. Please help
  65. Need Help ASAP :(
  66. Camber kits
  67. ABS/RAS/VCD/SLIP light all on!?
  68. Suspension Question
  69. Do i have to change pads when replacing rotors?
  70. Avg tire lifespan on hella flush drop and stretch tires?
  71. Do i bleed the brakes after changing rotors?
  72. Have you used rubber donuts to raise your car?
  73. Megan Racing Roll Center adjusters-Any one use them??
  74. 1" drop all around on 04 Coupe
  75. what should it cost to install 4 news shocks and springs
  76. Did lowering your G35 sedan screw up alignment (or anything else)?
  77. will the 2009-2011 suspension fit on a 2005
  78. Austin, TX. mechanic??
  79. HELP with upper A-arm bushings....
  80. adjusting bc racing coilovers
  81. All around brake recommendations
  82. 07 coupe & 04 sedan brakes
  83. Brembo rotors replacement/upgrade
  84. 09+ Brake Pads on 05-07?
  85. Slip and vdc lights are on
  86. Lower Ball Joints Need Replacing
  87. NEED HELP! in the middle of suspension upgrade
  88. Compression Rod Ball Joint keeps going bad?
  89. Bad break response don't know why
  90. sedan z springs front only. please advise
  91. Any body in Socal can replace my front shock top mount ?
  92. Any recommendations for brake pads?
  93. KW competition 2-way adjustable Coilovers **Reviews**
  94. 2005 G35 Coupe 5AT non Brembo Brakes+Pads
  95. Weird noise from my rear end of my G
  96. Raising 2004 G35 Sedan
  97. can the rear suspension be made stiffer without a drop ?
  98. problem with removing front wheel bearing...
  99. front LCA bushing recommendations
  100. HKS Coilover Dimension Question
