View Full Version : Brakes & Suspension
- Are 04 coupe and 04 sedan rotors interchangeable?
- Rear Brakes make a sratching sound
- Advice needed for suspension set up on 04 G35 Coupe
- Fortune Auto True Coilovers, Experiences/Opinions?
- extreme uneven brake pad wear.
- Bought unrevised z springs for my "x" before & after pics
- wheel bearing issue?s
- noise
- Swaybars
- Need Warranty Help from Tokico Retailers!!
- coilover install was going good and then this happend HELP!
- DIY SPC Rear Camber & Toe Kit Install
- 06 susp on a 05 coupe?
- installing my stance gr+ coilovers tomorrow have some questions PLEASE HELP!!
- New pads/rotor seriously hot and smoking
- G35 coupe with non sport suspension on 350z tanabe gf210??
- Cant adjust camber SPC
- Control arm question
- Advice: Which 350Z springs to put on a 06 coupe?
- Suspension shock question
- front end help
- SSR SP3 3 Piece Wheels and Tanabe Sway Bars Review
- Optional Sport Suspension?
- Are Centric 1000 series brake pads really same as OEM Formula?
- Suspension clonking noise
- Project MU Braking after Bed-In
- Switching coilover springs
- which is better
- Need HELP to equip my G with shocks, sways, and camber kit!
- Tein Flex collar removal question.
- Are caliper covers good at reducing brake dust?
- Will I need Camber KIT??
- Which shocks would work better for me?
- I bought TOKICO HP SERIES (WRONG ONE?) Please Help
- G35x front wheel bearings
- Tokico D Specs on front, HP Blues on rear?!?!
- help! any bagged car, i need help. g35 down!
- Problem after BC Racing and SPC kit install
- Question about tucking.
- Stoptech Trophy Sport BBK, anyone have em?
- Akebono BBK question: Please help!
- 350z stock spring??? ON G35
- another slip and vdc off light problem
- Just Purchased new Akebonos, but I think i got scammed, HELP
- Rotors help please!
- Where to buy OEM wheel bearing replacements?
- brake labs rotors
- Trying to get better tire life
- suspension help/problem, springs?
- Popping sound
- Question about camber kits...
- Do I Need a Rear Lock Out Kit with Ichiba?
- Energy suspension compression rod bushings
- flex VS. mono-flex VS. BC-coils VS. ?
- need help with dropped springs
- Brembo caliper thickness?
- need new brake pads
- alignment complete
- Clicking Noise Front of Car
- Brake Pads and Rotors
- Spring help!
- Who needs camber it's all about the toe
- Godspeed Camber kits
- SPL Compression Rod Bushings, A-Arms, New hub assemblies... Feels like a new car!!!
- question about rear setup on BC coilovers
- Lowering on 20s?
- H&R Coilovers adjustment....
- Spare wheel for Big Brake Kit - Please help
- RWD vs. AWD Sedan Suspension
- Stance gr+ oem
- Wagner Thermo Quiet Ceramic Brakes for 2003 G35 Sedan w/ VDC
- Help - New brakes and brake chatter
- Energy Suspension Front End Kit Installed!
- Will adding spacers make "feathering" worse??
- Help !! New rotors & pads, bedding question
- Not worth the time to try Z springs
- Help! I have a coil Spring question
- What breakes + Disk
- Rear spring rubbers...
- Need Help With Brembo Search
- project MU ebrake
- How low can you go....
- G37 Stoptechs on a G35?
- winston
- Eibach Pro Kit - Front Left Lower than Front Right?
- 350z springs Vs G35 coup springs
- true or oem style go lower?
- Uneven height, opinions please
- Brake fluid capacity?
- Compression Rod bushings - pics
- Grind noise while turning right
- 2003 G35 Coupe 89k Squeaking in Rear suspension
- torque down after sway bar installation
- Guys that are slammed on coilovers out there. I have a question about jacks...
- Revolution Brake/Wilwood BBK
- will 370z coils fit my G35?
- Stance GR+ Pros installed...pics
- Help w/ Compression Rod Install... Stuck Bushing
- what is the shortest after market shock out there for a g35/350z?
- What offset to clear G37/Akebono BBK
