View Full Version : Brakes & Suspension
- Who has replaced their wheel bearings/hub assembly?
- when to change brake pads
- car swerves under hard acceleration!? HELP!
- Best drop system?
- alignment specs question
- URGENT - Get me back in my G!!!
- RacingBrake 13" BBK Front and Rear
- Wanna lower my sedan by 2"inches any Help???
- Alignment Center/Price
- Need some review on Tanabe SUSTEC PRO S-0C
- stuck in brake job, piston wont go back in...
- whats everyone think?
- installed 350z unrevised = crappy ride..
- *Need Help* Squeaky Sound From Front Left Tire Area
- Big Big brake kit on G sedan
- recommend pads,rotors for me??
- Unrevised Z shocks VS 04 Gcoupe shocks
- height adjustment on tein basic ??
- What should I beware as I take my rotors to a shop to get someone to resurface them?
- quick wheel spacer question...
- tein s tech
- an air compressor for my g35?
- Problems with Toyo Proxes T1R
- DIY for SPC rear camber kit?
- Products used to spraypaint over chrome rims??
- Dual Valve Stems???
- 350z S tech few q's
- S Tech drop, need mods?
- rotors from pepboys = wrong size???
- suspension setup
- tanabe df210 owners chime in
- ...coilover blues...
- Which spacer should i get to make these flush and aggressive.
- Suspension Upgrade Overkill?
- Is this normal?
- when do you need to replace your shocks?
- Brake rotor suggestions?
- Brakes Keep SQUEAKING!!! -_-
- brembo brake question
- which collar for hotchkis sways?
- Good Price On BBK for fx45?
- $400 Spring Installation?
- im about to put 20's on my car......
- snow tire question for rwd owners
- G35 Coupe S-tech's on a sedan??
- HELP! mad scraping
- Please Help with CV JOINT
- Battle Version Camber Arm
- what kind of metal are the brembos made out of ?
- Tokico D-Spec
- Brembo Brakes only comes on 6MT ?
- One side lower after drop
- 350z Tein H-techs for 07 G coupe
- wht size spacer ? and brand ?
- NRG vs. Stillen vs. Richie v2
- Eibach, Project Kics or Ichiba Spacers
- traction controll not working
- basics installed...what is this damn clicking sound???
- Big Problem
- 05' G35 Lowered on 350z Tein S-tech *PICS*
- Something different?
- Tein CS, HKS RS, or Cusco Zero-2 coilovers?
- Hks Coilovers worth it with Universal Air?
- Need Assistance Diagnosing a Few Noises..
- $874 for 1 brake caliper and 2 pads?!
- G37 Brakes on a G35?
- how many miles did u have when u changed your shocks?
- Expensive spring install!
- Older 350z OEM Springs (Unrevised)
- KW Coilovers?
- recommended tire size for stock 18"s 03 coupe rear
- Loud, sharp *click* from shifter when brake is applied
- !!! Emergency Brake Please Help !!!
- Rotors, rotors, and more rotors (help me decide)
- check this AAM brace out
- Road noise....reduction?
- Opinions please, A-arms
- Brake pads and rotors.
- New Kinetix G35 Strut bar
- Creeking sound from the rear.
- Extra bolt on hub?
- Noisy suspension...HELP!!!
- New BBK- Could be the first G with this size? comment
- Can you use stock lug nuts on Volk GT-7's???
- Brembo BBK fitmnet
- Brake pad help
- will 350Z coilovers fit a G35 coupe?
- best suspension for my car?
- DIY Coilover install
- place for brakes!
- Rotorpros ??? when to replace stock rotors
- To tein or not to tein
- How long OEM shock will last?
- Wheels Direct Online are scam artists.
- Braking Data
- Brake Pads and rotors
- 2006 6mt coupe brake upgrade
- Question!
- megan
