- Trouble finding coilovers for 08 G35S sedan
- A/C Issues and questions... Scratching my head
- Is a G37 Fender interchangeable
- How to install a wing?
- 08 g35ss driver seat squeaky noise
- 2008 g35 Shop Manual
- After market Headlights on 2008 sedan
- Are performance mods worth it? (Read post)
- Thermostat broken bolt removal
- 2008 Infiniti G35x Rearview Camera Fix?
- Sticky Calipers! How's Powerstop? Need help...
- White Smoke Coming From Exhaust
- Crankshaft Socket for G35
- Where is everyone?
- Upgrade 07-09 Non-Nav and Old Nav to: Newer 2010+ NAVIGATION Setup
- Sunroof leak
- Instrument cluster swap
- Hr vs 2v
- Sunroof leak passenger side checklist
- Optional Tire Sizes
- 2008 g35 v36 rattle (tick noise sorta)
- Rattle from engine bay, at idle only, when turning steering whel
- Wheel options w/akebono swap.
- Ac line is leaking r134a hose is connected tto radiator all metal
- car over heats when driving over 75
- How to replace rear license plate light bracket on 2008 g35 sedan
- Suggested G35 S Musts
- 08 G35X Please help before my wife kills me :)
- Passenger Door Lock Issue
- Multiple electrical gremlins after engine replacement
- Bank 1 VTC Cover Removal
- 2007 G35X - Fans don't turn on until 212°F
- 2008 Infiniti g35 code p1757
- Car starts when it wants to
- Would you buy this 08 sedan base auto?
- 08 Sedan Nav screen upgrade
- How many resonators does a 08 g35 have?
- 08’ g35 sedan cold air intakes
- Help solving engine/exhaust rattle/knock at idle
- Need help !!
- 07 G35x with 370z rays and nismo rays gram lights 57f
- 2008 g35 power steering pressure hose
- Which wire is for the reverse light positive lead ?
- Headlight upgrades
- What have you done to your G35 this past week?
- G35x Sedan 2007 install a OEM GPS kit
- Need help! Planning to install oem camera trunk lid to aftermarket
- HELP! Steering wheel lock / car wont turn on
- our cars are easy break-in (theft) targets
- Acceleration issue?
- Coolant heater hose connector replacement but still having mystery smoke after engine
- Car shaking violently - Suspension issues?
- Need help! 07-08 g35 sport sedan headlights
- Infiniti g35(V36) transmission modding
- Opinions please ~ on condition of car after "fix"
- 2007 infiniti g35x wont start,wont crank,
- 18x8 wheel 35mm offset
- Exaust fitment?
- Right front suspension noise
- Weird issue
- G35x problems with front axle
- OEM front lip non-sport part number?
- some system stop working, front console (radio, a/c, power seat;windows, rear defog)
- Telescoping wheel won’t raise...?
- Headliner Removal
- 2007 g35x 7 speed swap
- 2007 G35X - Overheating mystery - Fan speeds oscillating beyond 212°F
- 2008 Infiniti G35 misfire
- TCM question
- Looking to buy
- Got a good one for someone. P0102 error code won’t go away.
- Need Service manual
- 07 sedan engine fitment
- Single Turbo Kits?
- In fail safe or limp mode
- 07 Sedan headlights
- Need to run wires from license plate area
- G37 bumper on g35???
- 2008 g35xs with g37 bodystyle
- Need help before dealing with these dirty mechanics
- 2008 G35 sedan front bumper
- 07 g35 sedan power loss no check engine light
- Aftermarket headlights 08 G35X sedan
- 2007 G35X Won't Start : Anti-Theft?
- Weak cold start
- Gallery Gasket extras
- P0171 code on my 08 g35x
- Total loss value for '08 G35XS??
- 07 g35 sedan no start completely dead
- Ark Test Pipes on X
- Rubber window trim and weatherstripping
- 07 g35s 6mt car cuts power at 4.5k rpm
- Hello everyone O2 sensor question!
- White smoke!!!
- 08 g35 different size tires
- Back up camera?
- Hesitation after ECM reset
- Where can I buy a Zex window switch for nitrous
- Tire recommendations & spacers
- Wheel recomendations??
