PDA
View Full Version : G35 Sedan V36 2007- 08
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132
  1. Horrible Customer Service at Infiniti of Melbourne
  2. What is a good amp for Kicker DCVR10 10" with 2 Ohm final impedance of 1600 watts(800
  3. Tachometer Reading Super Low (video) in 2007 Sedan
  4. shift knob replacement options for automatic
  5. Stripped stud on strut tower
  6. black headliner...done!
  7. interior trim removal how to?
  8. Analog clock not keeping time
  9. Exhaust rattle at idle
  10. How To - Subwoofer and Amplifer Install on a 2007 G35 Sedan with BOSE
  11. Transmission Flush $199 too cheap?
  12. Air bubble or dirt under tint?
  13. Third brake light
  14. Brake Part Numbers for Journey Sedan
  15. a/c only works when car moves??
  16. Aftermarket exhaust, how much muffler NOT to show.
  17. how to remove the shifter in automatic?
  18. Window problem
  19. Installing a used exhaust?
  20. key fob
  21. 10 g37 bumper on 08g35xs?
  22. Dash board light question and HID question
  23. Car Overheated and Went Into Limp Mode - Clueless
  24. Front wheels squeaking/screeching during turns. Need insight
  25. 2008 G35 Sport with Automatic Transmission???
  26. AC quit on me today
  27. 2007 G35 Sedan Fog Lights?
  28. Help Help Flooding Issue
  29. Video not working on center console 08 g35x?
  30. Replace my cat converter with something else?
  31. New with a question
  32. Front lip questions!
  33. Grille/Trunk Lip Dipped!
  34. Work in progress... 2008 G35x sedan
  35. anyone replace upstream o2 sensor?
  36. Front Console Power outlet Not working
  37. Any maint. to look at around 60-70K?
  38. Anybody else notice Phil is gone?
  39. lugnuts size.
  40. Front-end creaking / cracking noise after idling
  41. 2009 door pull okay on 2008? Also, anyone use the Altima's?
  42. Sunroof / Moonroof Stuck
  43. Line Out Converter for Aftermarket Subwoofer
  44. Short Crank / Hard to start issue
  45. bumper Fog light inserts
  46. Wrecked my G
  47. 2008 G35 Sedan
  48. 2007 G35 sedan V32 any solid or urethane transmission mount ?
  49. g35 and g37 front bumper
  50. Crazy deal right now on full Catback Sedan Exhaust
  51. Recurring Battery Drain problem 2007 G35X
  52. For 6MT owner, clutch feel improved after clutch fluid change at 58k imles
  53. BlueTooth Static Noise
  54. Has somebody this bumper installed on sedan?
  55. How to keep the car running cool in hot days
  56. Getting new wheels-input or feedback/TSW
  57. Oil warning light on
  58. Factory stereo upgrade?
  59. Door lock mechanism issue
  60. Tire pressure reset after puttion new wheels on
  61. Adjust '07 G35S AT footrest/dead/dead man's pedal?
  62. Wheels suspension : newbie
  63. front and rear camber kit
  64. Part number for plastic clip/screws
  65. Looking for wheel advice on G35X
  66. Long crank / hard start issue 07
  67. How often do you need to refill the coolant reservoir?
  68. buying rims! would this fit?
  69. Would the spare tire clear Akebono BBK?
  70. Dedicated Track Car?
  71. Just Finish Summer Mods 08x
  72. 350z mid pipe on 08 g35S Sedan...??
  73. JDM passenger (USDM driver) convex mirror fits PnP
  74. P0014
  75. Broken armrest?
  76. My rear wheel is getting cooked!
  77. How do I know if my G had a tune
  78. Noise after startup....new intakes
  79. 2012 IPL Wheels on 08 G35S Sedan - TPMS Question
  80. 2007 G35 Journey Window Creak (rattle)
  81. test pipe CEl
  82. Black Grille
  83. My X's transfer case starting to leak?
  84. loud pitch sound from engine bay
  85. Want to drain/flush all fluids and other services
  86. Sudden change in miles per tank (gas)
  87. fair price to replace thermostat, flush coolant, new radiator cap?
  88. 2008 G35x Front Wheel Bearing/Hub Noise
  89. slight hesitation
  90. headlight promblems?
  91. Testing out carsponsors, 08g35s 4dr
  92. TPMS replacement
  93. Rapidly Heating Up?
  94. Is my door missing something?
  95. 6MT Sales Numbers
  96. check engine light
  97. check enging light
  98. Blue tooth only sometimes connects when getting in the car
  99. Oil question
  100. i need spring rate recommendations for coilovers
