- Replacing Struts & Shocks. Do I need this Part?
- Going with Nitrous. Best place to buy?
- Sport Wheels were rotated by mistake. Follow up?
- Strange knocking/braking front wheels '07 G35x
- Car shuts off when I try to take off
- Passenger Seat Switch Stopped Working, Now working
- Car died while in motion
- 2008 infinity G35 XS
- Cruise control relocation
- HFCs
- Installing aftermarket Subwoofer
- No sound from all speakers (head unit is working)
- Need Confirmation for Upstream O2 Sensor Please!
- G-ECU/ECM firmware
- Transverse link bushings - replaceable?
- Identify Wheels
- Ticking noise
- 08 g35 sedan
- Best Tuning Options for 08?
- Collision
- Turn vdc on
- Best mods?
- AC controller unit might be bad or faulty need help resetting it or replacing it
- When the AC button is on , is the compressor engaged all the time ?
- Overheating when ac is on and parked for 15 minutes on idle
- New Steering Wheel
- Passenger headlight problems
- Upgraded my tires
- Lazy downshifts in manual mode
- Brembo brake calipers
- Can't get cooling fan bolts out
- Steering wheel removal help
- Cam code away with oil change....
- Myterious Tire Air Loss
- Looking to service my ac system
- Revenge of the click 😒
- Steering Wheel Removal HELP
- Calling RWD 2008 G35 Sedan Sport Manual Owners
- P0430 and P0128 Codes
- Wheels and Tires
- Automatic Transmission
- Is the G35 the Japanese BMW M3
- Hearing rattling noise in Driver rear wheel area
- What's my chances looking like
- DIY Napkin / Tissue holder
- Just installed a sub
- Compressor clutch not engaging
- Does our head unit have sub RCA out
- P0455, SES on, then off ?
- 2008 G35X vs G35Xs
- car cranks for a while before turning over
- OEM Backup camera install
- Where to download owners manual??
- How much should I pay for this 2007 G35 Sport Sedan?
- Just Bought a G35x
- Stainless Steel Brake Lines?
- Stutter and code
- Test Pipes for Exhaust
- Fuel Pump Issues
- P0021 code fixed?
- 2008 g35xs 116,000 miles stock spark plugs?
- Upstream O2 sensors @135k mi: replace?
- Sounds clogged and like a rotary engine. G35 2007 sedan
- 2007 Infiniti G35s Seean
- Car hesitates/dies when accelerating from a stop
- Single exit exhaust?
- Redline is actually 7900RPM?
- 07G35 Stutter In Power AND Stalls Randomly (Automatic)
- Transmission Issues
- Production Numbers
- Y pipe G35X AWD
- P0420 + p0455
- G35x Subwoofer raddle issues after new sub install
- Axleback worth it?
- Suspension Problem - sway bar link fix
- Stock G35 speakers?
- G35x mod compatibility
- Wet Floorboards on passenger side, already attempted fix
- What is this piece?
- 2008 g35x AWD sport buyers guide
- Busted Dash - Need Odometer Readings
- Factory Service Manual Help
- Made new bracket for 400hz horn!
- I-Key Intermittent issue
- paddle shifters!!
- Quaife LSD questions
- Need help choosing new diff
- Looking to buy an 07-08 sedan, scared of gallery gasket issues
- Strange stuttering issue that occurs about 5 minutes into warmup
- 2007 G35X AWD Suspension Upgrades
- cup holder insert
- Best current option - Aftermarket Camera / Sensors?
- Waterpump
- Wet Carpet on the Inside of G35XS
- Left side speakers not working 07 G35x
- 2008 Infiniti g35X Front Brake Solenoid (P1757)
- Security light solid on
- Just Picked up Salvage G35
- 08 hissing noise
