- Oil question
- i need spring rate recommendations for coilovers
- 2nd Gen Odometer lcd leaking?!?
- Needs some good advice - Bolt broke while installing Thermostat 2008 G35 Sedan
- can i remove the exhaust heat shield?
- Transmission Fluid Flush & Cooolant Change Intervals
- Differential Oil Question - 2008 G35x
- totaled :( WRX or G37?
- Transmission Hesitation/Delay Engaging Reverse/Drive
- Issues with 07 G35x
- Need alignmnent, can I trust a chain like NTB?
- NEW TO G35Driver, 60K maintenance & other things?
- New Stillen rear spoiler review plus spoiler comarison
- Need advice before i spend money
- Romoving Oil Cap 2007 Sport Sedan
- Trying to fit 19x11's out back..
- Grounding Kit Options
- gtm rtp issues
- Better intakes?
- AC Compressor Vibration
- Hit curb, now all warning lights are on.
- Dunlop SP Sport Maxx TT - good tire?
- G35x wont come out of park
- Anyway to update radio display to better resolution?
- Nissan ATF fluid
- Cnt racing hfc
- Are these services overpriced?
- Anybody has problem with leaking coolant reservoir?
- Need help figuring out 0-60...
- on screen clock
- Paddle Shifter Questions?
- Broken Ashtay Spring *image*
- I know the trend is to DEbadge, but...
- SES Light after TB Cleaning
- Make my car faster
- V36 sedan Accuair eLevel build thread
- how do i take off my 08 sedan spoiler?
- 2013 GPM Map Update $99 (Limitied Time)
- Staggered tire on g35x/07
- 312,933 Miles on an M45!
- My first G!
- Clutch slave cylinder questions
- Engine "tick" - need help. Video
- CF card problems
- Newbie Q's/wheels..and interior paint issue
- Tires are 8/32 Depth, had a blow out - Replace 1 or pair on G35x
- Engine air filter uneven
- New Owner of a G35S, have some questions.
- new to the forum
- Is my G35 in theft danger?
- OEM Brakes on a 2007 G35S Sedan
- Potential 08 G35XS Owner!
- Question Regarding Losing A Key Fob!!!!!!
- Heated Seats TSB DIY
- Problems with new g35x
- Eibach Sways or Pro Kit Springs or Kit?
- Berks HFCs
- JDM A/C Controller + Custom ABS Radio Faceplate = Misery or Deliverance?
- New wheels recommendations/feedback
- Rotors and Pad Replacement
- Dedicated G35X Subthread area?
- Passenger Air Bag Sensor Glitch? (Dash and Light different)
- 30 mpg!!
- Extended Thread Lug Nut
- Engine maintenance soon light
- Question regarding Auxillary connection
- Drove with no air filter, should I be worried?
- Concept One Wheels: CS-6.0 G35 fitments available
- Wheel fitment question: V1 350z track rims with stock suspension?
- Factory Tune Necessary?
- 1 Key Fob => 2 Cars
- 2008 G35X Sedan - correct battery size?
- Recurring P0021 Code
- Weird trunk issue
- New G35 Owner!
- 2007 upper console in my 2008 - let there be (2 led!) light!
- Chin Spoiler Lip for G35x 2008
- Clutch fluid level?
- convex mirror glass?
- Steam from under hood?
- Can somebody help me out here? Need this one part to complete my exhaust!
- Drilled or slotted rotors pikz?
- Brief review of Swift Mach springs
- Did my DYI brake bleed with ATE blue over the weekend
- G37 all-black / maple door panels and dash on my g35
- CD player not working
- Question on Sound....?
- Rear Brake Wear
- Service Warranty for G35x
- Sedan midnight tails - full with the trunk lights
- Strange Clicking Noise
- So my car got vandalized...
- MPH Correction
- Help, size spacer to make wheels flush.
- Help! Custom exhaust question (mufflers)
- twin turbo???
- 2007 G35 Journey Rear End Squeaking
- 08 G35S sedan modification
- Back in the G!!
- Modifying my G35
