- Rear brake question. Dumb?
- Website for OEM part numbers?
- Adding OEM Navigation to my G35
- Magnaflow Magnapack Mufler drone
- Windows going crazy after battery died? + question about interior rattles
- Thinking of Purchasing a high mileage 6MT sedan(advice)
- Gas cap
- window regulator, the same as coupe??
- aux 3.5mm
- Stiff steering wheel after hitting something
- Check engine codes? Can't figure out what is going on. BCM?
- Quick Transmission Question
- CAI or SRI?
- Where is the starter?
- Test pipes
- New to Infiniti
- q50 HID bulbs fit my 07 x?
- 2007 G35x Warranty - Currently 100K Miles
- Door won't open. Gotta love the winter
- Front lip
- Please help- car wont start!!!!
- Exhaust video clip - Tanabe axleback, Post MAF Silicone Tubes, Dry Filters
- RPM seems too high
- Difference between oem spoiler with navigation and without?
- Rear caliper options; Cardone a no go
- I want to make my G a monster...
- What brand headers do you guys recommend?
- How to disable factory alarm completely?
- NOOB post; rear brake caliper question
- Dball2 issue
- Looking for some intakes
- Good Exhausts Systems???
- JDM style SKYLINE badge on v36?
- Gains in horsepower?
- Air Intakes
- 08 G35 sedan Rwd. U JOINT
- Replacement Parts for 07 G35x
- My 07 G vs. Acura NSX
- 200k miles!
- Homelink acting up
- diffuser
- Question about the 07 G35x, and also wanted opinions on a particular car
- intakes
- 2007 G35s Sedan Sub and Amp Install
- 2009 G37 COUPE BRACKETS ON A G35 2008 SEDAN? will they fit?
- Alignment Question: SAI out of spec
- Installed Eibach rear camber arms
- Tanabe axleback, Mishimoto Post MAF silicone tube, Upgr8 Dry drop-in filter review
- Crackling noise
- Lowering suspension question
- Auto rear windows
- Carbon Fiber Trims
- What i hate about my 07 G35X *RANT*
- G35: To buy salvage or to not buy salvage
- G37 Sport MT Tire Size
- Wheel size questions
- Distance of FOB unlocking...
- Lowering springs
- Driver's door exterior unlock button not working
- Just had my 8 year old G35x detailed :)
- wiper blades...
- 370Z Suspension on 08 Sedan HELP NEEDED
- 07 g35 sedan 6mt chip. Yes or No ?
- oem rims insert defects
- EVO-ALL remote start with DEI smartstart review
- tire pressure question with 19inh toyos on a X
- wheel spacers
- Need help for mods
- Are these legit HID Bulbs?
- Rain water leaking in and need help ASAP
- Wiper Blade Refills
- 2007 G35 Sedan Bleeding clutch
- 2007 infiniti g35x window wont go up
- Tire Pressure Warning Light
- instrument cluster
- 90k service 2008
- Mystery of the missing engine cover emblem..
- looking in to replacing my cat converters
- 2008 G just turned 200K
- 07 G35 Pinion Seal
- P0024 Code
- Exhaust Help
- six digit bad luck
- Water pump maintenance not listed?
- Best Place to find parts?
- Can't force the A/C On
- Door armrest 08
- 2007 Infiniti G35 x sedan door speakers specs.
- Removing cat heat shields.
- Removing cat heatshields
- help with tail as turn module wiring
- Buying tips
- Fuse box location for 12v outlet - 2008 Infiniti g35xs
- Did my first oil change today and noticed an obvious problem!
- what do you guys think about wheel spacers anyone got them?
- 2008 g35 S sedan
- How to Improve MPG
- Question about headlights
- 4.083 Gears
- 07 g35s 5at just brought it
