PDA
View Full Version : G35 Sedan V36 2007- 08
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132
  1. Winter drivers: Any rust problems or issues?
  2. Tire pressure warning light not going away
  3. gas smell inside car when heater is on
  4. Proud new G owner! G35S 6MT
  5. Car jerks while accelerating/driving
  6. Bulletproof so far
  7. Torque Steer?
  8. 2007 G35 need new clutch/tranny job, worth it or new car?
  9. Getting video on 2007 Infiniti G35 x
  10. Custom Tail Lights
  11. 08 sport fogs???
  12. Remote Start for 2008 G35x
  13. Would a bad brake bleed job (with air in the brake line) ruin the brake system?
  14. Replacing rear shocks only
  15. First day with my new 07 Black Obsidian G35S 6MT
  16. 07 G35 sedan cai
  17. More Rear Right Tire Wear ??
  18. P0152 and P2A00
  19. Hope I didn't ruin my transmission
  20. MAF sensor cleaning
  21. Part number for Eibach sway bar confirmation
  22. any trouble spots at 60K? (to use extended warranty)
  23. Car Name
  24. Looking for a NEW to me G
  25. MREV question
  26. Eibach lowering springs grinding noise over speed bump
  27. 2008 G35X:Upgrading OEM HID bulbs
  28. rpm gauge stuttering around 2000 and below but never above.
  29. Is this a good deal?
  30. G35X on Staggered Wheels
  31. What kind of noise does bad sway bar links make?
  32. Painted outside metal door/window frame
  33. Questions on brakes pads on wrong side of caliper and cylinder head leak
  34. Nearly stalls on warm start (video) . . . going to get worse?
  35. Break Job advice
  36. is the 2010 grill compatible with the 08?
  37. Pair iPhone 6 to '08 G35 Journey w/ Nav
  38. brake lines?
  39. Idle Hesitatation no Service Engine Light
  40. Warning Notification Center Cluster not responding
  41. Looking at purchasing an '07 or '08 x sedan
  42. Extending Warranty Beyond 60K
  43. Would a 2009 chin spoiler fit on my 2007?
  44. RHD Parts
  45. 2007 v36 Bose Sound System
  46. Car Won't Shut off unless lights are "OFF"
  47. can i put 245/45 18 on the front end of my 2007 g35 sport sedan?
  48. Exhaust timing or ECU flash? (see video)
  49. 2007 G35X - Ride not feeling smooth anymore
  50. best aftermarket rotors/pads for a 2007 g35 sport?
  51. Cat Heat Shields Gone
  52. just scored a sick deal, any suggestions?
  53. tip tronic quesion
  54. Chirping noise coming from under the car
  55. UpRev Tuned
  56. Maintenance Tire
  57. FYI - For replacement battery, try Nissan Dealer
  58. Slight hesitation during light take off.
  59. 2007 G35s no start help needed
  60. Engine Hissing Noise
  61. Oil Change at Dealer?
  62. 07 G35X Sedan exhaust from G35 Coupe?
  63. key fob buttons stopped working
  64. Weird idle
  65. Foglight Change
  66. Jack Bolt Size on OEM Front Rotors
  67. Infiniti Elite Warranty - Suspension
  68. Aftermarket Wheels
  69. Wife had incident with G this morning
  70. 07 G35x Starts... Then Stalls
  71. Automatic Shifter Replacement
  72. AWD G35x .... AWD working on 3 tires?!??
  73. New xS Owner
  74. Steering Wheel Removal Help
  75. Head gasket question
  76. 12.9 MPG, 234 miles on full tank on dash in 07 g35x sedan?!??
  77. Nt 830 nittos on 350 gt skyline.
  78. Intermittent Ticking/Chattering from Engine Bay
  79. 08 different cup holder option?
  80. Car is kicking and wont rev past 2.500 rpm
  81. POLL : black grille vs stock chrome grille
  82. Muffler delete - drone at low rpm's
  83. AC clutch replacement
  84. Looking for input on what minor to add?
  85. TPMS replaced...now what?
  86. car struts quik when descending speed once n a while (feels similar to a tranny slip)
  87. door light replacement and part?
  88. JDM NISSAN Sport Horns, anyone?
  89. G35X not Shifting into park all the way
  90. Brake Pedal Assembly in Parts Diagram?
  91. Performance Mods
  92. runs rough and keeps kicking code p0345
  93. Belt tensioner torque
  94. New G35 owner
  95. Potential Engine Replacement needed
  96. Need pass. intake boot
  97. can i re-tape mud guards on my 07 g35x myself?
  98. Idle Issue with Muffler Deletes
  99. Brake+Gas Bad for Power Train?
  100. Rough Hesitation/Kicks
