PDA
View Full Version : G35 Sedan V36 2007- 08
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132
  1. 2008 g35 sedan poor idle
  2. Back up camera install
  3. Heat on even when temp set at 60F
  4. Minimum height for jack stands?
  5. Exhaust question!!!!!!!
  6. Gasoline smell outside of car on cold start
  7. G35 Computer mpg screen?
  8. can't figure out how to remove front caliper
  9. Need help with buying......
  10. 2007 Infiniti g35x sedan
  11. New suspension recommendations
  12. Tiny Metal pieces in test pipe
  13. Tire Question
  14. This is probably goodbye...G Totaled
  15. Where can I buy this piece of trim?
  16. AFS Warning Light
  17. Chiming/Rattle Noise coming from engine bay
  18. Fuel Filter Question
  19. 2008 G35 headlight bulb replacement
  20. CF Wrap for scratched door bezels & steering wheel trim.
  21. Has anyone ever experienced this???
  22. Exhaust
  23. Engine Click on idle
  24. G35x possible engine swaps
  25. replacing cluster
  26. Carbon fiber interior trim to replace my woodgrain?
  27. Naked Exhaust End
  28. O2 sensor wiring help
  29. Headers Question on 07G sedan
  30. Intakes...the debate continues.......
  31. Most wanted Carbon Fiber parts
  32. 2003 g35 front lower ball joints question
  33. Air condition delay
  34. Need Help Finding Door Molding
  35. Advice on replacing INFINITI Decals
  36. Backup camera not longer able to see
  37. 2007 G35 Sedan front lip for Journey (Non Sport)
  38. Engine crank case oil breathing tubes
  39. Reduced Engine Output/Throttle Response
  40. Trunk open indicator
  41. Gas Tank
  42. 2007 Infiniti G35S Sedan Sputter Issue
  43. Trunk is really hard to open
  44. D3100 XS Battery in G35x sedan?
  45. Headlights
  46. Innacurate Maintenance Reminder
  47. 2008 g35x 4dr - interior trim/shifter/wheel repair
  48. Potentially getting new shoes for the G.. thoughts?
  49. P0455 error
  50. Window Master Switch Not Working!
  51. Strange Vibration
  52. Taillights
  53. Replacing shocks & struts
  54. Mildew smell when on "Fresh Air" mode
  55. Locking and unlocking the G with the key fob
  56. P0057 Fuse location?
  57. G35S question!!!!!!
  58. 2007-2008 G35 motor mount compatibility-different part numbers
  59. Questions about Denso Factory Plugs
  60. Replacement for G
  61. Can Matic s trans fluid replace Matic j?
  62. Looking to do a customer exhaust
  63. 2008 Infiniti G35X: Body Control Module needs replacing??
  64. headlight issue
  65. vdc/abs/slip lights on randomly - yes, another question
  66. New Member (Pictures) & Questions about Front Splitter
  67. Engine Overheating Question
  68. need help with a few things
  69. Need help with a gasket size.
  70. 8 year maintenance items?
  71. question about clutch master cylinder cap
  72. Which option is better?
  73. Aux
  74. Short driving vs. long driving
  75. OBD connector
  76. Running the G35x on all different tires
  77. Distance sensor shorted out - major component
  78. Hand Stitched Steering Wheel Wrap (DIY w/ PICS)
  79. Should I get all new tires and brakes?
  80. New to the G line!
  81. Front Lower Control Arms for 2007 G35 Sport
  82. 18" Infiniti wheels that looks like G37 19" wheels? 0.0
  83. tpms light
  84. Tires
  85. How do I disable factory alarm on 07 g35x sedan?
  86. Installed weathertech visors and passenger window goes down
  87. Help! Is my engine knocking??! (Video Inside)
  88. Anyone use Bosch aftermarket o2 sensor?
  89. 2007 Journey sedan audio question
  90. Cold air intake
  91. Service and Oil
  92. AC stops working and then start working again
  93. Cel code u1000
  94. Need dimmer switch part number.
  95. Car Hesitation help/advice needed pls - 2007 G35
  96. VDC off, slip, abs, low tire, brake lights on. help!!!
  97. Shop charging 2hr labor to replace rotors
  98. Drivers door won't open from outside only
  99. Hypertech not seeing ECU
  100. Ash Tray/Cigarette Lighter Removal??
