- starter problem?
- 07 G35X - Post Throttle Bodies Cleaning Idle Hunt - SOLVED
- Heater and A/C not working
- G35 has had headlight bulbs swapped from D2S to 9005
- How to turn on bluetooth
- What do y’all think?
- Stuck in P2A00 Hell
- Exhaust leak and sulfer smell. Replacement?
- so long..
- engine surge(buck) at lowspeeds with light throttle
- unlock ignition switch
- Catalytic Converter Fitment
- AFS - Constant Twitching
- San Jose repair shop?
- How to get Bluetooth iPod/Music w/ Functional Display & Controls
- how to connet my music off my phone to my car
- Does anybody know any aftermarket sites for a sport bumper?
- 2007 G35 Won't blow any air from the vents after being turned on in the morning
- Rear Center Seat Belt Stuck
- Fise Box Cover 07 35 Behind Battery (Help!)
- Florida Owners - Irma
- Radiator Crack!
- Fare Thee Well My Infiniti Bros
- Need Help Finding Part
- P1217 01/02 Experience?
- Battery stops charging when car is warm??
- Battery drain located...
- Torque Pro with wireless OBD2 scanner
- Help with overheating issues in traffic with A/C on.
- it gets really hot after driving 10 to 15 minutes.
- Turn signal working but has stopped clicking
- Battery dies? again
- Splicing airbag cables safe?
- Higher than normal RPM
- Need urgent help identifying this part and where I can find it!
- RPM High at Idle Error - What Could it Be?
- Insurance
- Low RPM when Idling
- 2008 Infiniti G35 Sedan Base Mods
- Help With Headlight Removal
- SES light - code P0455
- Sunroof drain flood, BCM problems? [help]
- Adjusting HID Headlights
- 2008 Thermostat
- No problems after cleaning throttle TB
- New G35S Owner
- Program new key?
- Serious sun glare on center display
- CEL after ECU Reset
- 18" Nissan Maxima Rims on a 08 G35X Sedan
- 370z Suspension on 07 G35 sedan.
- Quicker throttle response after ECM
- Interior relay identification
- Time for maintenance!! (What plugs?)
- Is it possible my 07 G35 journey have VLSD?
- Staggered wheel Tire Rotation
- 07 Journey with vlsd
- Evaporative emission vapor vent tube warranty letter
- Good deal?
- Buying an '07 Sedan- What to look for?
- Bluetooth turn on isssue
- Xenon HID Headlight
- Lights in tachometer on and off
- AC Blowing Hot Air
- 08 Auto G35x 4 door/Momo Automatico Shift Knob
- Ahoy, mateys
- G35x base bogging-then dieing upon take off under low rpm
- Marks on my Hood!!! Help
- Door locks repeatedly clicking to lock position while car is on or off. Any ideas?
- New MAFS or not?
- Motordyne Plenum Spacer
- '08 G35X Sedan Window Trim Peeling Issues
- Horn won't honk!!
- Won't start, single click noise
- Inside Buzz / Resonance behind dash area
- Help please
- engine rattle from right passenger wheelwell
- Tail as Turn Signal Mod
- Stutter when starting to accelerate, need new spark plugs?
- A/C Blowing Cold then Hot and back
- how many miles is considered high mileage?
- Vague steering
- Transmission fluid pan plug...crush washer?
- need opinions.. new wheels
- 2008 G35x premium package-nav SUSPENSION PARTS REPLACMENT
- 2009 G37 Base Convertible, I can't find a Cat Back that fits my car!!!
- Front o2 sensor
- Halo headlights
- AC condenser replaced whats next?
- Error code C1500 - Chassis
- g35 07 Sedan making weird noise and search bar is no help
- 2007 Bose amp connector
- Where Can I Buy a Sport Front Bumper??
- Help! Rear end vibration under slight load
- AC is not cold, won't take R-134A
- New Owner of a 2007 G35X
- Smart key issue
- Ongoing error codes
- Got some 20s!
- Lowered my g finally.
