PDA
View Full Version : G35 Sedan V36 2007- 08
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132
  1. My OEM intake hose is cracked, will the intake hose from a 2009 G37 Sedan fit?
  2. Rear driver window won’t work
  3. Stutter between 2nd and 3rd Gear
  4. What the hell is this?
  5. Changed Spark plugs... crank, but no start
  6. OBDII Issues "Not Ready" for Inspection and P1148
  7. G37 rear bumper cover on G35?
  8. No Key Detected Error after I wash my car and park outside overnight
  9. Spark plug p/n ?
  10. Automatic Transmission Drop Resistor
  11. 07 sport staggered tires brands that are best
  12. Auto Door lock clicks constantly
  13. 2008 g35 headlight issue/fog light
  14. Please help g35 vdc slip on
  15. Backup camera
  16. Gauge Pods
  17. Engine Splash Shield
  18. Where do you buy your cheap OEM parts?
  19. Transmission codes p0735 and p1757
  20. Change Differential oil
  21. Axle advice
  22. Coilover question
  23. New owner - Questions
  24. Underglow wiring
  25. Has anyone ever changed a rear CV shaft and or wheel bearing hub assembly???
  26. Question about how high you like to get your revs
  27. Console power socket
  28. Need help Disconnected wire/car starts when it wants
  29. Please help just replaced wheel bearing assembly and cv axle
  30. AWD and new tires
  31. Power steering pump replacement cost
  32. 2007 G35x surging headlights and interior dome & starting problem
  33. snapped
  34. One Touch 3 Blink turn signal mod?
  35. 2007 G35x -- How reliable is it???
  36. low horn tone not working
  37. Starting issues sometimes it’s starts sometimes it doesn’t
  38. 08 g37 coupe exhaust on 08 g35 Sedan?
  39. G35X 2008 Weird Sound Please Help
  40. Hood Damper
  41. Uncontrollable Heater!
  42. Stuck Tranverse link 35x
  43. 2007 G35 hesitation at 1K RPM
  44. Motorad Thermostat. Good or Bad
  45. 2008 g35x 19inch rims
  46. Spinning bolt for shock to lower control arm 07 35x
  47. 2007 g35 sedan sport vs non sport suspension, do they mount differently?
  48. More Intellegent Issue & Antenna Location
  49. 2007 g35 sport brakes & rotors
  50. Are you running 350z wheels on your 35? <<<<< opinions needed
  51. Bank 2 sensor 1 problem
  52. Center Stack Not Working
  53. 07’ G35 sedan starting problems
  54. Is there any way to get the 08 G35 Sport Edition sedan front bumper??
  55. ECM Fuse Blowing !!! NEED HELP !!!
  56. Wind noise issue
  57. Telematics
  58. DIY transmission fluid drain plug torque value
  59. Click from door or b-pillar when coming to a stop
  60. 2007 G35x radio works intermittently
  61. G35X Clicking won't start
  62. Starter issues
  63. What color is the headlight light
  64. best sway bar 08 g35x
  65. Codes C1109 P1217 and P1212
  66. radiator replacement.
  67. Engine ticking noise when reving.
  68. 08 g35xs awd sedan suspension help
  69. For a O7 G35s sedan bought OEM G37s coupe 19" wheel
  70. Absolute Best Way to Remove a Wheel Bearing Assembly
  71. Weird starting problem... please help if it sounds familiar
  72. Turn off oil maintenance light
  73. 2007 G35x Sedan Wheel bearing confusion O.o
  74. Rough Engine Until Raining?
  75. 08 G35 window switch bezels
  76. Both Side view Mirrors Not working
  77. Where is the AC relay?
  78. 07 G35x
  79. No headlight indicator in cluster
  80. 2097 g35x o2 sensor replacement
  81. Idling problem
  82. 07 Infiniti G35s swap
  83. Everytime I reset my ECU...
  84. rear view camera issue’s( trying to Resolve)
  85. Help with p0011 and p0021 please its annoying!
  86. Temperatures gauge reads hot with AC on after 45 min.
  87. My 2008 G35 Radiator failed
  88. Fender dented
  89. Carbon Signal CS V2 Conversion Bumper (makes g35 sedan look like g37)
  90. A question about gasoline
  91. 08 G35x Sedan Rack and Pinion Dealer Can’t Get It Right
  92. New wheel suggestions.
  93. G35x 2008 with 4 prev owners
  94. rack & pinion seal kit or remanufactured unit?
  95. Is it worth buying a single owner 2008 G37x?
  96. Where can I get louvers.
  97. Key not recognized
  98. Blue brake rotors
  99. Has anyone been able to get louvers on the v36 sedan?!
  100. Urgent help !! Wiring
