PDA
View Full Version : G35 Sedan V36 2007- 08
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132
  1. Need Advice: Replace Engine or Sell Car?
  2. WTB: oem hr y-pipe
  3. Replacement bumper for 2008 Journey Sedan
  4. HELP! Strong lurch and
  5. Does the rotors warp quickly on these cars?
  6. Is 90K miles high for a 07-08 G35?
  7. VDC OFF, ABS , SLIP and AWD LIGHTS ALL ON WTF
  8. Sport Bumper
  9. Takeda cold air installation problems
  10. cruise control
  11. Front Brake Question
  12. Problem with automatic windows
  13. Bluetooth
  14. Standalone ecu tune?
  15. really need help with my headlight situation
  16. No lights, cluster and dash.
  17. Satin black trunk, hood, and roof??
  18. Anyone have 275/35/19 on a G35 sedan?
  19. Total Power Outage While Driving, help!
  20. installed headlight bulbs, fine for a few weeks and now this
  21. springs/camber labor price too high?
  22. Seat bottom swaps?
  23. 2008 V36 Sedan - Creaking Chair
  24. New G35X, What is this aftermarket switch??
  25. Master Driver Window Switches acting up
  26. 2008 g35s sedan suspension question!
  27. test
  28. 2008 G35 Brake Master Cylinder
  29. Steering rack compatability
  30. When braking backup camera turns on.
  31. Best source for OEM sport bumper from G37?
  32. Dumping the six disc changer in the trunk?
  33. OEM Navigation Update for 2007-2009 G Sedan - $79 plus installation
  34. Newbie G35Xs Sport Lip Question?
  35. Akebono Big Brakes, now need spare tire
  36. thermostat
  37. New owner, a few questions...
  38. Blinker ticking noise stopped working
  39. upper and lower exhaust insulators worth to replace?
  40. anyone have led turns in front? where do resistors go?
  41. Fuel Filter?
  42. PCV fittings
  43. Possible new owner
  44. Q40 emblem installed
  45. 2007 G35x trunk won't open.
  46. New to G35
  47. Should i buy an aftermarket warranty with my 08 G35xS?
  48. Cruise control SET button not working at all?
  49. Vibration 2007 G35.
  50. Bleeding Brakes. What DOT Fluid to use, 3, 4 or 5.1??
  51. 07 G35X Sedan (Tech Package) Adaptive Headlights vs Non Adaptive Headlights
  52. Wrapped Chrome Trunk Trim
  53. Moose's Build Thread: "Kaminari"
  54. Wheel Bearing - OEM or Aftermarket?
  55. OEM Rotors and Pads
  56. Installing Front Akebonos only
  57. check engine code p0031.. o2 sensor
  58. StopTech Sport kit problems.
  59. want to drop my 07x
  60. DIY for exterior door handle removal?
  61. 2007 G35x Exterior Mirror
  62. 2008 Sedan Sport Rack & Pinion Leak
  63. Question About Getting Service Done
  64. G35 Journey, stalls, stumbles, slip, SES, ABS lights on
  65. 370z Exhaust Fit on a V36?
  66. electrical problem
  67. Front drive shaft
  68. steering wheel locked, brake and battery lights are on
  69. 07 Infiniti G35x VDC & SLIP Light
  70. re-attaching rear splash guards
  71. Memory seat buttons not working
  72. 2007 g35 sedan no radio, a/c controls don't work, navigation don't work
  73. Staggered Wheels Rotation
  74. summer tires or all seasons for G35S
  75. 07 Sedan Paint Issue
  76. Memory Seat gone
  77. Sticky or seized caliper
  78. "Power steering rack leak"...
  79. Trunk stopped opening after this
  80. 07 G35x Sedan, Three out of four Power Windows/Locks don't work
  81. Installed Tanabe Medalion Exhaust
  82. fast intentions exhaust 07 sedan
  83. First post. DIY midnight grille (w/ pics) & wheel question
  84. isSuspension noise? Clicking sound when car moves side to side
  85. Car randomly shuts off when switching from park to drive
  86. Sport Model Owners - Do we need to replace the VLSD?
  87. LCA for G35X
  88. LSDs in an X?
  89. Is the rear diff still the best place to jack up the back end?
  90. Disable Intelligent Key Link to Seat Memory
  91. Best vendor for floor mats for our cars
  92. 09 G37 oem spoiler on 07 G35x sedan?
  93. Rear Plate Light bracket beyond repair.
  94. G35 to G37 conversion. Fenders?
  95. Replacing the info screen betwixt the RPM/MPH gauges? Also, update NAV look?
  96. Need new brakes - Toronto, Canada
  97. Replacing Day time running lights
  98. Keyless Remote Case
  99. OBDII trouble codes P0014 and P0024
  100. Uneven Pad wear
