PDA
View Full Version : G35 Sedan V36 2007- 08
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132
  1. Help finding a fender for my g35 2008 in k23 color
  2. 2007 Sedan Oxygen Sensor Computer issue
  3. Need help, slip, abs, brake, and vdc lights all on after 10-20secs of driving.
  4. 2007 g35x wont shift gears, brake wont move
  5. 2007 G35x
  6. Wheel Fitment Help
  7. 07 G35x running staggered winters?
  8. tachometer light broken
  9. Blown VQ35HR
  10. Hitting the "rev limiter" at 5-5.5k
  11. G35 Fuel Gauge issue
  12. Merry Christmas G35'ers
  13. What's the OEM part number for the daytime running lights ?
  14. Which fenders fit
  15. G35 2008 AWD(Identify)
  16. New tires for winter
  17. 2008 G35x tiptronic shifter not working
  18. All I hear is droooonnnneeeee
  19. Help! Parasitic Battery Drain
  20. Starter Problems - sign of other issue?
  21. Alternator randomly not charging
  22. Center Screen Dashboard Not Working
  23. First mod list
  24. I got saggy bottom, boys...
  25. Can anyone here tell me what's going on with these flashing SES codes (video inside)
  26. 07 G35x Radio / AC issues
  27. Fuel pressure issue I think
  28. Infiniti VS Lexus
  29. Will g37 test pipes fit on 2008 g35
  30. G35 Sport - Whirring/Warbling sound coming from below gear shift boot area
  31. need replacement speed sensor bolt
  32. '07 G35S fuel damper replacement
  33. Cars been sitting for 2.5 years - need advice
  34. DIY - How to reset your tire pressure monitoring system without going to a dealer
  35. Rusty Subframe Replacement with Older Al Version
  36. U1000 p1815 p0615
  37. DIY: Tranmission Fluid Change
  38. Limp Mode
  39. Engine and Transmission Mounts
  40. Engine Stutter (Hesitaion) at low RPM (under 2k) when cold
  41. Independent Shop for Working on 08 GXs
  42. Timing chain
  43. What is the most likely cause of wheel wobble
  44. G35 Rubberbanding
  45. Help pillar gets wet when it’s raining
  46. Catalytic Converters bad - best option? Berks?
  47. 2007 G35 Journey RWD Persistent TPMS Light
  48. Drivers door lock issue
  49. 2008 G35 Sedan Throwing P1757
  50. What part is this? Pictures included
  51. Broken SEAT!
  52. Coolant Question? (Stumped)
  53. 07 sport sedan with rays 19s
  54. oil found in spark plug well
  55. Location of tranny speed sensor
  56. Anyone else have their license plate light support bar in the rear bumper rusted out
  57. Tires... alignment... maybe suspension?
  58. Won't accelerate no error codes
  59. 2008 G35 Sedan V36
  60. 2007 G35 Sedan Alternator replacement
  61. P2A00 and P0850
  62. 2008 Sedan Heater Hose Replace ment
  63. Blower Motor Troubleshooting
  64. How do you diagnose an exhaust leak
  65. Sylvania 9006 led fog lighr bulbs
  66. Rear brake pads
  67. Engine Blown
  68. Cruise control set flashing
  69. Y pipe exhaust
  70. Advice on bad wheel bearings
  71. TransGo shift kit for 5AT
  72. Performance Ignition Coils🤷‍♂️
  73. 07 G35 Sedan Sport Lip Install
  74. How To: AUX Input + BLUETOOTH Adapter Kit Installation Guide. OWC Upgrades
  75. How do I fix this crack or what’s my best option
  76. Car stalling/electrical issues
  77. 2007 G35X A/C not working
  78. Overheating at idle?
  79. coolant reservoir help
  80. 07 G35x Frame connector rotted off?
  81. hoping for some purchase advice - 08 g35x sedan
  82. Whoops I tore the boot…
  83. inside of front tires worn out
  84. 07 sedan with Bose , any stock speaker replacement?
  85. My diff will not go back on the car
  86. Nav Question
  87. New member from Canada, 08 G35x
  88. Fuel door help
  89. 08 G35 DOA due to GPS short
  90. Rough idling and acceleration
  91. Is seperating the Radiator from the AC condenser possible?
  92. Question TCM/valve body question
  93. The most Bizarre problem ever! Keyfab battery causes car failure!
  94. Limp mode safe mode....
  95. G35x No crank. Starter Not clucking. Power to cabin
  96. G35x No crank. Starter Not clucking. Power to cabin
  97. Help with big coolant leak on G35 sedan
  98. Trouble finding coilovers for 08 G35S sedan
  99. A/C Issues and questions... Scratching my head
  100. Is a G37 Fender interchangeable
