- Headlight replacement
- adr wheels ( dv-8 )
- Engine Fluid Leak? (pics)
- Service Engine Soon Light on but no codes???
- G35s, TL-S, IS350? Which as a family DD
- Parts Compatability
- GTR Exhaust on G35X?
- G WON'T Start!!! BCM???
- Lowered Springs Ruined Shocks...
- 08 G35x need help with C1104 and C1108 ABS code *Many Lights*
- Weird Closed/Open Loop Issue
- Coupon Code for Navteq Map updates
- G35x with Avant Garde M310
- Whining sound from engine bay!?!
- garage door opener
- 2008 g35s Clutch
- belt tensioner
- Oil Change DIY
- How to unclip the orange and yellow steering wheel SRS airbag clips?
- Rattle/Squeak Center of the Dash below the vents
- HID flickering (Driver Side)
- Question about Rims
- G35X Lowering Question
- Dealer says high beam is out
- 370z Akebono BBK on V36?
- Humidity Inside Car?
- Besides rims / tires / driver, what's the best bang for bucks to make a lighter car?
- Strut Brace for 07 G35X sedan: GTSpec or Cusco?
- Tires
- Small Coolant Leak
- alternatives to OEM tires
- DoT Matrix replacement??
- V37 headlights
- Wiper issue
- 08 Journey Lip
- Engine problem (small or big problem)
- what else do i need??
- Exc Sport/Sport
- Test Pipe/Exhaust Combo
- So this started happening to my interior... with pic.
- HELP! RADIATOR Hose Leak?
- Rear spoiler
- Backup Camera
- anyone looking for a steal on some coilovers??
- Front CV Joint Damaged Need Assistance
- anyone know what this part is called?
- 2007 G35 Sedan Headliner... Issue?
- G35 Navigation upgrade issue
- G35X reversing problem? Tranny issue?
- Is the speedometer and Odometer tied to the front or rear wheel?
- Looking for indash cam to stop hit&run
- Group 35 vs. 24F Batteries (Photos)
- Opinions on what to do next?
- missin my G
- Throttle body question
- ICC when it's cold?
- Need help changing the stearing wheel trim!
- Taping into the Bose Amp?
- Locking doors before they are closed
- Lots of shaking
- Tumbling sound coming from underneath
- Weird squeaking/rubbing when I turn right
- Weird Squeaking or Popping Noise
- Bad MPG? Check your brakes
- Quick question about rims
- Do I need new plugs?
- G35s front chin spoiler
- engine turns off at slow speeds
- Adapter for Android
- 08 G35s sedan numbers and times
- Driver's side molex
- Question need your input!
- Fuel Cluster light went out
- Did the dealership get one over on me?
- 2007 G35x rim - years & models?
- I need some help for tune my g
- Hotchkis swaybar owners, check your bushings
- What is this interior part called?
- 2007 G35S intro.....
- 2007 Bose amp replacement part numbers?
- Accidental mis-shift (over rev)
- Tinted tail options?
- Those with Quaife LSD .. QDF10L
- They dont fit!!!!!!!!! :(
- 200,000 mile review!
- Steering wheel / instrument pod stuck
- Looking for good remote starter.
- Rough ride at highway speed
- Door Not Opening from Both Sides?
- Filled the gas tank, read full. Parked it now reads empty & Service Engine Light on
- What is the thickness/diameter of the rear sway bar on a G?
- OEM & Aftermarket Parts info
- Played with a G35s with tinted windows driving across I80w in PA today...anyone here?
- P0021 - Camshaft POS - Location
- Another goodbye and thank you thread.
- Skyline V36 FSM
- Older Ipod only for factory interface?
- Had some fun in the snow today :)
- Eibach Prokit part number not matching.
- Sticky Dashboard, wet carpets!
