View Full Version : G35 Sedan V36 2007- 08
- V36 sedan a good car?
- autokits x?
- Greddy
- Tokico Blues part number
- Strange electrical issues with my G35
- Audio/Navigation Broken, how to replace?
- BBK Install Question
- Need help please
- Pretty sick deal on illuminated kick plates
- Sell my G35?
- bcm 07 g35x questions
- ABS, VDC, SLIP, AWD lights on...Any Nissan/Infiniti Techs out there?
- Power window and door lock control not working.. please help
- 2008 G35 Sedan Front End Wreck Headlight Problem
- Power Pup ECU Mapping
- metal hum at low idle
- Went to Irvine Car & Coffee and saw this :)
- Looking for 07 G35x Rim Suggestions
- Running problem after batter change, possible throttle relearn?
- 2007 G35 Journey Door Stopper (Check)
- Did we get the Raw end of the Deal? 2008
- Switch in Center Console Arm Rest?!?!?!
- belt noise?
- Intelligent Cruise Control Limitation?
- Best aftermarket rotors for OEM pads?
- 07' Infinity G35x engine interchangeability?
- Car Stalls After Starting Sometimes
- Windshield Wipers
- 2007 G35S 6MT Transmission problem
- Warranty Question...
- 2007 G35 Engine Emblem
- Thick Coolant in Reservoir.
- BBK Issues
- Weird P code comes on and off (evap leak)
- Disable Auto-Recording on Hard Drive
- Recommendation Needed for a New '08 G35 S Owner
- Parking Brake Tensioning on 2007 G35 Sedan
- HELP! Tire size for coupe 19s!
- nooooooob alert!
- New to Infiniti
- Errrr? That was weird.. stall
- Having a few issues and need some help
- Is there a Head light aim adjuster??
- Horrible gas milage?
- Wrenching, and hoping, and praying... and buying
- High Start up RPM
- Potential G35s Owner!
- manual trans and differential oil
- Tires?
- G35X - water damage from storm
- G35 cup holder swap
- Camber Question
- Old Infiniti Out New Infiniti In
- New 2007 G35S owner with some questions.
- I need help for 60k miles service!!!
- Future G35 owner... pointers/advice?
- Rim spec of '08 Sports sedan and '11 Sports sedan?
- windshield washer change-out?
- UCA and LCA's - symptoms?
- Tax returns? I think you meant coilovers.
- Stock HIDs replacement bulbs
- Hit 100000 Miles...Recommended Maintenance?
- Help! Car Accident.
- Question About Vossen CV1 Rims
- G35x Progress
- MT shift knob removal
- Need help on my 07g35s
- Headlight problem!
- Goodbye G35S!!!
- Stock Exhaust Tip Replacement
- Akebono BBK Install Question
- Finally traded her in...
- G35/37 System Diagnostic Screen? Anyone try this?
- head unit upgrade?
- Lowest mileage 07-08 sedan?
- Navi Backup Camera question
- Gas smell in cabin
- Door Issues
- injen CAI
- websites to find out what cars were when brand new?
- Drained the wrong oil pan..HELP!
- Possible CKS option for awd
- Motor / Engine Mounts G35 Sport
- Front lip, rear trunk lip, rear window lip
- Buzzing Noise when Starting up and Accelerating?
- My new 2007 G35 sport sedan
- Q about Headlamp indicator on the Instrumentation Cluster
- 2007 Sedan front alignment (not lowered)
- Engine not starting (battery is fine)
- insulation under hood?
- Finally got snow! First snow drive with my X.
- 40,000 mile long-term review of BC BR Coilovers
- replace of driver seat-bottom or repair
- Fan speed knob stopped working?
- Thinking of Getting Hotchkis Sway Bars
- Whistle noise in cold weather
- How to tell if endlinks are shot?
- Need help on part# quick!
- No 5th gear...
- Paddle shifters price.
