- Fix for check engine light from test pipes!
- For those with SWIFT springs: needed a camber kit?
- 2007 G35x Sedan with 2004 G35 Coupe 18" 7 spokes
- Window and cold start problem.
- Stolen Car (overheat)
- Quick Question
- Rattle in passenger side
- what has the dealer done to my brakes?
- Headlamp switch
- Ticking sound coming from the motor
- 07 G35 sedan Passenger headlight not working
- Need a body shop in Houston or Central Texas
- Wtf?
- Tail of the dragon
- G35 fail
- Painted my taillights (GTR style)
- xs rim size?
- Issues that i couldnt figure out how to fix
- Where to buy the OEM Infiniti red "S" emblem?
- What Wheel Spacers Are You Running
- Warranty help with brake judder tsb
- Calipers
- When to change out the diff fluid?
- first oil change
- Squeeking when turning left
- headlight question..
- Sport bumper and the hook hole...
- 2007 G35X AWD fuse
- Free XM!?
- Goodbye G35 forum moved on to something else..might be an interest to some of you : )
- Need Part # for Master Switch Cover
- Bye bye 05 G35 coupe, Proud new owner of a 2007 G35s!!
- Stalling issue, need help.
- Center Console Screen Repair Question
- Widest 2007 g35x with stock 17 inch
- How to connect a Samsung Galaxy S3 to G35?
- Dirty speedometer.
- Shifting from Park to Reverse
- Question on stock springs
- Stealership lost my OEM wheel key...
- Will this oil filter work?
- 08 G35 Spark Plug Replacement, need help
- Splash Guards Sports vs Journey
- any good places for my 2007 infiniti g35x other than dealership?
- wheel spacer size
- Where to get stealth front turn signals
- Clucth pedal problem??
- New to the G
- self-maintenance
- weird electrical issue
- Mini-review of the Orange TPMS Retrofit Kit
- Stillen gen 2,Takeda or R2C.
- Maf sensor problem
- Quick question about replacing Rear Sway bar
- Comfort/Quiet Tire for 18" Sport Rims
- new to g35!
- Crossover Points / Polk/ General Audio
- New to G35!
- quote for repainting front bumper
- Installed Grounding Kit
- ngk 4469 $7.99 at Autozone YMMV
- G35 XS w/ Stillen
- 2008 G35x wheel fitment
- need some oppinions and expertise here...
- Any safe way to remove the small pits & scratches on headlight covers?
- Best clear spray paint for taillights?
- interior vinyl wrap??
- 2008 G35 Clutch Help!!
- AC evaporator condensation - how to drain?
- 08' G35x Staggered Set up
- Ballast out?
- 2007 G35x sedan with 2008 G37S coupe 19" rims
- For people that track or autoX their V36, tips for a track day?
- $198 for rear pad installaion (labor only) + rotor resurface?
- Smart Phone Vent Mount Suggestions
- Dash trashed by winshield installers, recommendations?
- 2007 Bose Speaker System
- 10+ rear bumper on 08xS(pics inside)
- bottom back seat
- Update!! Check It!!!!!!!
- Question: About my lowering springs
- at 50k miles, finally the mods that were well worth the cost
- hi everyone
- Dash peeling (PASSENGER SIDE)
- what's under the lower valence grilles?
- Steering wheel sex
- Help Identifying Exhaust Parts..
- Cruise Control Issue
- sport lip
- motordyne xyz
- My experiment with Plasti Dip and trim
- Oil light won't reset
- Grounding kit Wire
- White smoke and leak got me worried.
- Banshee horn
- V36 G35 sedan vs. 2008 G37 coupe?
- Help please!!!!!!!!!!!!!!
- exhaust upgrade
- My AUX button in 2008 G35 isn't working!!!
- "You know what grinds my gears" or my factory rims??
