PDA
View Full Version : G35 Sedan V36 2007- 08
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132
  1. Slamming a 07 Sedan
  2. G35 RPMs drop when accelerating at highway speeds
  3. 07 g35 sedan one v belt or two?
  4. 07 G35 sedan sport ac drier with switch port or without?
  5. Horn doesn’t work, airbag light flashing. Already replaced clockspring
  6. Some buttons no longer working door locks and windows
  7. Full Titanium Exhaust for Sedan
  8. Need help looking for obd bluetooth phone app for 07 g35x
  9. 2008 G35X to 2010 G37 Radio for bluetooth
  10. Should I get my Old G35 back?
  11. Belt chirping on cold starts
  12. What tires should I run for my rears
  13. NA or FI
  14. SRS airbag light flashing code 15??
  15. AFS delete
  16. VERY BROKEN Nissan 350z VQ35HR Engine Teardown! Did Anything Survive?
  17. 2008 infiniti g35 sedan 6spd manual
  18. Water pump decisions with 245k on the clock
  19. Help Identify stolen modules
  20. Water managing to leak inside
  21. Wont accelerate normally after heavy rain, advice is appreciated.
  22. Car problems
  23. Differential Service + Transfer Case Service
  24. 2008 g35 sedan tsb question
  25. Bank 2 camshaft position sensor 08 g35x
  26. Error code P1078
  27. Vvt solenoid replacement
  28. Got a new ride - replaced the G for a GS
  29. Window seal melting off
  30. U1000 after P 1757
  31. Passenger window issues 07 G35s
  32. Opinions on my exhaust setup for my 08 g35x?
  33. Lowering a V36 ~ 1 inch Questions
  34. Y pipe
  35. Worst instrument cluster ever?
  36. What’s best tuner for 07-08 g35 vq35hr
  37. Exhaust
  38. Car Hesitates on Acceleration From Stop?
  39. What sound is this? It started appearing once I lowered my car on coilovers?
  40. Tricks to remove plug blocking thermostat bolt?
  41. Strawberry Milkshake of Death
  42. Intermittent P1757
  43. Need help suspension question
  44. Any factory Parts No Longer Available?
  45. Replaced window belt molding today
  46. Do the g35 sedan and the g35 coupe have Interchangeable exterior parts?
  47. Interesting Climate Control Issue, need advice
  48. Passenger Door Realignment
  49. Hey
  50. New Guy Check-in
  51. Anyone know where I can get some clear tailights?
  52. We're being spammed to death by Desmonds
  53. Vdc off - slip
  54. Parking light bulb?
  55. Clear coat peeling from spoiler
  56. Bad noise, but no code
  57. Heavy exhaust smell after gutting out cats
  58. What am I missing?
  59. Horn Won't Work
  60. CEL after gutting out my catalytic converter
  61. Transfer Case tool needed?
  62. V36 Type S, SP and P info
  63. 2007 seats interchange
  64. Hooking up scope probes to ECM wires?
  65. factory backup camera never worked
  66. Motordyne catback :)
  67. VQ35HR Power Steering Pulley
  68. Dyno results
  69. Another water Leak Thread...
  70. New idling sound after cleaning throttle body
  71. G35x Won’t start U1000 After Tcm reinstall
  72. Car won't shift out of park
  73. Banging noise and car stutters on launch
  74. Sensor monitor status issues
  75. 08 g35x came with backup camera but you CAN’T use it?
  76. Does anybody have the list of preloaded songs on Music Box?
  77. Anyone know what this thing is at back of engine?
  78. Parking Lock issues
  79. Clean Driver side factory drain?
  80. What Breaks?
  81. How Much Should I pay??? (labor)
  82. Broken ignition coil bolt
  83. Shifter Park Pin
  84. ATF, Differential, Transfer case, what??
  85. 08 Sedan Won't Crank
  86. Rain causes huge electrical issues, unknown origin no leaking into car
  87. Fuel Gauge problem
  88. Cruise not working
  89. 08 G35x sedan
  90. Anywhere I can get a sport lip from?
  91. Sport shocks for V36 AWD
  92. What's your opinion on Walmart's SuperTech Synthetic Motor Oil
  93. Flickering Interior lights
  94. What hose is this?
  95. Headlight not working
  96. System Daignostic
  97. Can I resync the throttle pattern?
  98. Water Pooling Under Batter In Rain - Effects Circuitry
  99. VQ35HR O2 sensor P2A03 code
  100. Do they make a split CV boot kit that fits our cars
