- info on good aftermarket HID kits
- Key Light and Cruise Control
- What is the best way to add sound when I am rubbing the engine
- Snow button /AWD?
- Strange buzzing like noise in the front end of the car
- derp derp question
- Voice Recognition/Bluetooth problems
- 2008 G35 Maintenance/Long Trip
- My new Daily Driver G35S w/ C6 Vette comparison
- steering response
- Racial Profiling
- Fuel pressure regulator fuel leak.
- Updating NAV Maps
- Cant explain.....
- plasti dip opinions appreciated
- Cold Cranking Amps required for 08 G?
- Top Speed exhaust. Better with Y pipe?
- 2nd Gen Car Show Pics
- official WTF AWD thred
- Oil catch can?
- winter question?
- steering rack from G35xS to my G35x?
- Z33 mods on the V36
- Brake juddering/"warp"/shudder info
- Need a front lip?
- Service engine soon light?!?!? HELP
- Wheel bearing or what?
- Passenger Door Rattling
- Hardstart
- Had a retarded idea, would it work?
- Yellow Exclamation mark (_)
- Firestone lifetime alignment not so good?
- cf card problem
- need new brakes
- Changed my oil from M1 to Castrol
- Check Engine Light
- Is my overdrive working
- sandy raped premium gas
- Redesigned Valve Covers for V36? another spark plug tube seal thread.
- 100k Miles Maintenance
- quick question
- 07 G35S 0-60 time opinion
- KNS Brakes - Pads and Rotors for your G
- Click sound
- Who has had their bottom seat cushion replaced?
- 2-port USB Car Adapters..
- how much free play?
- new guy from mn with some ?'s
- Front end noise suspension problems
- Spark plug shortage??
- License plate lights do not work
- G25x vs G35x Suspension
- Coupe 19s
- Earls hose clamps
- About to do my service
- Replace brake fluid @ dealer?
- Front sway bar links
- Nrg washers
- Passenger airbag light
- Road vibration/judder gone!
- Anyone know an good DIY for G35 Sedan 08
- Is the G35x front wheel based or rear?
- aluminum drive shaft
- Warranty runs out in 7 days. Anything I should have them check?
- Newer Owner
- False trunk open warning lights
- Tpms
- Joining the V36 family.
- Help with rims and suspension but warranty issues
- Do we have an official DIY on MAF?
- Replacing DRL/Fog light bulb on 2008 G35 sedan
- Sedan rear diffuser??
- Replacing bulb DRL/Fog Light bulb on 2008 G35 sedan
- Red GTR
- Crashed my car I'll post pics tomorrow
- dealer claims Eneos ATF (not engine oil) is OEM Matic S and J...
- are my tires bald??
- What would u do?
- What type of oil are you guys using?
- maintenance
- 2008 G35x knocking noise when turning steering wheel
- Coolant system capacity?
- Can I fit 4 Tires and rims in my car?
- Carbon Fiber Hoods/Bonnets?
- Engine Air filter
- Running with out TPS
- Hail damage
- Anyone know what this part came from??
- Road noise from Front Left tire
- new owner
- LED Question
- Driver's Side Door Interior pull/switch bezel and console cover
- Tb
- Will 03 g35 coupe rims fit 08 g35x sedan
- OEM Infiniti Car Cover?
- 6mt shift from 2nd to 3rd
- where do u guys buy oem engine air filters from?
- Cracked my heated driver side mirror
- Roof spoiler
- CarrProof - minor accident - YAY or NAY?
