PDA
View Full Version : G35 Sedan V36 2007- 08
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132
  1. Undercover bolt torque?
  2. Had my battery replaced, and I need help configuring some of my old settings
  3. AUX inputs
  4. Bad G owner! :(
  5. Recommended tire sizes
  6. Help! Car ins't starting.
  7. Squeaky noises
  8. Reading AT Temps?
  9. AC compressor and expansion valve replacement
  10. 2007 G35x Sedan Oil Light Issue
  11. Power stutter when accelerating gently
  12. Changing front bumper
  13. Farewell and thanks!
  14. Fastener Stripped - Repair Advice Needed
  15. My window regulator assembly went out of place. Need help!
  16. 07 G35s sedan suspension
  17. Second gen questions!
  18. Hotchkis Sway Bar Settings Recommendations for 2008 G35XS?
  19. P1757 front brake solenoid
  20. Aftermarket sub and amp install
  21. Navigation
  22. Engine noise
  23. Wobbling while driving
  24. Help Identify Calipers/Pads
  25. 370z suspension fits 08 awd g35 ?
  26. Alternator connector wire colors
  27. Power Drivers seat, Steering wheel, and mirrors not working?
  28. Some one tried to break into my G :(
  29. White possibly dried out window switches/seat belt latch
  30. Crooked shift knob?
  31. Newbie Questions about G35S Brakes & buying parts
  32. Help Identify This Part
  33. Diy for axle install? Awd 07
  34. 2008 g35x sedan performance y pipe
  35. New build: g35 sedan
  36. Weird key fob issue
  37. Squeaks from suspension
  38. Shifter stuck in Park / No Fans / No Console / No Cluster Guages
  39. Bad Engine 🙄
  40. Custom grille?
  41. Pic Request: 19x10.5 22 / 19x10.5 22 or 19x9.5 22 / 19x10.5 22
  42. BCM reset, is it possible?
  43. Annoying Buzz Sound at 1200-1400RPM?? 08G35xs
  44. New wheels
  45. Debadging
  46. Infiniti g35 overheating maybe thermostat
  47. Offsets?
  48. FI 18" and RHFC or FI 12" and RHFC
  49. Car registration says G35S, but I don't seem to have the features...(in South Korea)
  50. Hazard light/Yellow Key light on!!!
  51. High fast idle?
  52. Where can I get a good ballast for 08 g35
  53. Should I buy this 2008 Sedan with less than 17,000 miles ?
  54. Fuel Gauge stuck on full
  55. Oil level >higher< on dip stick
  56. Unusual vibration
  57. Alternator going bad?
  58. Thread Count for Tow Hook Same for 2008 X Models? (Front License Plate Bracket)
  59. Car too high mileage for Aftermarket Products? G35xS 2008
  60. Access to A/C Evaporator
  61. High gas consumption.
  62. Coolant bleed valve on HR motor
  63. Car Won’t Start 2007 G35x
  64. 07 G35s Screeching Noise
  65. Tried to repair 08 g35x Sedan radiator and this happened any ideas?
  66. First Post...newbie...help needed for a possibly blown engine
  67. Aftermarket Blower Motor brands?
  68. Stillen Gen 3 Ultra Long VS K&N Typhoon Dual CAI (Winter?)
  69. Please help Identify hose
  70. 2007 g35x rough idle and sputtering
  71. Partial Tach Light Dysfunction
  72. Helpful leak locating tip?
  73. Headlight questions
  74. a picture is worth a thousand words
  75. Passanger Sunroof drain leak - Final solution
  76. Lound boom noise when shifting into 3rd gear in manual mode
  77. No interior lights, no blower motor???
  78. G35 P0021 and P0024 Repair $
  79. Help!!! Need Help finding stock Banjo bolts g35 sport sedan Rwd
  80. Catalytic converter part number question
  81. Upgrading my rims - HELP
  82. G35 Offset Rims
  83. AC Compressor Replacement
  84. New owner 2007 G35S sedan 5AT upgrades
  85. Car starts but stalls immediately
  86. 07 G35 (vq35de) dipstick reading over H?
  87. Please Help me out?!
  88. Anyone upgraded their Navigation?
  89. Anyone have anything similar to 19x9/10-1 in the rear?
  90. AWD light on G35X
  91. D S rear door panel removal
  92. Water leak, more than I want to chew.
  93. G35 pads on g35s
  94. How many original '07-'08 V36 sedan owners still here?
  95. Intermittent battery light on
  96. TransLab or TransGo Shift Kit?
  97. Lowering Spring Kit for 2008 G35x
  98. Leak in trunk
  99. My OEM intake hose is cracked, will the intake hose from a 2009 G37 Sedan fit?
  100. Rear driver window won’t work
