PDA
View Full Version : G35 Sedan V36 2007- 08
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132
  1. G35 rack and pinion
  2. Radio: A/V Control Unit Replacement
  3. Some questions about Performance & Brake system
  4. 2010 bumper conversion - done
  5. Question on plastidip emblems then re-attaching
  6. Direct Injection (direct ignition)?
  7. First winter on my G35x... Infiniti stealership recommended setup
  8. Exhaust Sounds Different after a Tune-Up?
  9. Front passenger side window question..
  10. G35S and G37S sedan uses the same lug nuts?
  11. VQ35HR...Need info on programming/chip
  12. Power Steering Pump Issue
  13. G35 or G35s?
  14. Changed from M1 EP to PU today and noticed
  15. Post drop alignment???
  16. Cost of replacing the the clutch at the dealer?
  17. Have insurance replace engine or replace myself
  18. AWD vs RWD 07-08 G35 Sedan..Need Feedback/Experiences from owners
  19. Corroded rims?
  20. Totalled the G...
  21. 2007 g35
  22. Air bag light flashing 2nd gen sedan
  23. Continental Extreme Contact DW doesn't have 225/50/18?
  24. Exterior Sedan Body Changes
  25. Air Intake Track Cleaning
  26. Rattle from passenger side front wheel
  27. Tire fitment question?
  28. Horrible Luck
  29. Creaking noise when going over speed bumps
  30. Difference in Base/Journey/Sport in G35 Sedan
  31. Gas cap no longer hisses?
  32. TIRES - quick tire question
  33. Wheel fitment question?
  34. drag raced my car!!!
  35. Bye G35S
  36. Should I get a tune up?
  37. Sell it? or Keep it and Fix it?
  38. Dash cluster flickering
  39. computer problem? e brake lights go on while gas release
  40. 07 G35s starter question
  41. Which direction should the MAF face ?
  42. Slotted X-drilled rotors
  43. test pipes
  44. 2007 vq35hr...best exhaust
  45. Stillen Lightweight Flywheel
  46. OEM Sport Lip discontinued!?!?! WTF.
  47. Suggestions on what to add to add fun factor
  48. Trying to find my old car
  49. 2nd Gen vs 1st Gen backseat room?
  50. DIY Refill Freon
  51. Spacer question on 07 G35X
  52. ECU tuning question.
  53. Chrome or vintage gold?
  54. Launched from 3rd gear=burnt clutch. Help
  55. All the G35 & G37 Sedan Factory service manuals here
  56. Car turns off if i accelerate slowly(after battery changed)
  57. Getting my 60K service Done.. But......
  58. DIY Replacing Steering Wheel Bezel v36
  59. Took car to the dealer because of stalling issues and....
  60. Wheel bearings going bad / already bad?
  61. New to the G world--Exhaust upgrade question
  62. ordering OEM parts
  63. Accident - Wiring Question
  64. Oem non-sport lip for IP
  65. Reflash to solve abrupt throttle?
  66. Slits in exhaust? Just bought used G35... help
  67. Brembo Swap Question
  68. Struggle with SES light
  69. Cleaning the filters on the Stillen Gen3 CAI
  70. Steering wheel shake - HELP
  71. 2007 sport front chin
  72. 2007 G35 Muffler delete
  73. Downhill question.
  74. center console side dash near glove box falling apart.Glue recommendations? pic
  75. BBk rebuild and powder coat?
  76. headlight question
  77. Erratic RMPs after cleanning MAF Sensors
  78. 08 dashboard warp on cluster lid
  79. It's official
  80. 08 G35xS Very sluggish after long trip..
  81. under engine shield
  82. Just ordered a Valentine 1...some Qs
  83. Car alarms... My neighborhood officially turned ghetto.
  84. Displaying telemetric data on my Nav Screen?
  85. First Post, Wheel and Tire Questions (MRR GT1)
  86. Car almost stalls, but doesn't..
  87. Ebiach prokit lowering spring what's good strut combo for it
  88. Headlight Spider Cracks b/c Vinyl Overlay?
  89. 08 xS Eibach Spring Question
  90. 2nd Gen GASKET PROBLEMS ??
  91. Ummm.. Is glass covered?
  92. meisterschaft exhaust installed video
  93. 2007 - 2008 V36 G35 has zero lift?
  94. My headlights are jacked up!
  95. Brake Light blinks when you floor the gas
  96. New to Forum.. Looking for infomation
  97. Any Master Mechanics here ??
  98. Help with Bodyshop Error?
  99. 2007 G35S 6MT with navi question
  100. Part number for this piece, please help
