PDA
View Full Version : G35 Sedan V36 2007- 08
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132
  1. Transmission Rebuild or Swap?
  2. Installing factory back-up cam Questions
  3. Chasing this issue for months
  4. Air bubbles
  5. Will 350z/g35 coupe coilovers fit on 07 g35sedan ?
  6. Bluetooth
  7. VTC Retarders P0014 P0024 Advanced Timing
  8. Thornton OBD chip question
  9. Mystery front side cameras - are they factory?
  10. Cooling fan, what’s next?
  11. Intelligent Cruise Control Issue
  12. Vds and slip light on after rear subframe swap
  13. Spark Plug Thread Repair Kit for 08 G35 Sedan
  14. Aftermarket Android Screen - Boss speakers/sub
  15. Wondering what route I should go
  16. Radiator fans
  17. Blue slate g35x with spoiler?
  18. Car not starting and amber key light on dash
  19. What is the correct outer tie rod part numbers for the '07 AWD?
  20. 08 g35 what is the wire harness that connects to the dryer thing on the radiator?
  21. Drivetrain Fluids Drain and Fill
  22. Need help from the VQ GODS
  23. Rim refinishing advice
  24. Major $5k repair for 07 G35s. Keep or sell?
  25. Tip to remove drivers side front inner axle on an AWD X?
  26. Need some advice
  27. Brake lights won't work
  28. good aftermarket catalytic converters?
  29. RPMs hunting a bit at idle
  30. AC Black Death
  31. 2008 infiniti g35x CAI, cams,and exhaust options
  32. Intelligent key issue
  33. G35x 2008 headlight connector
  34. Fixed Brake Fitment questions?
  35. Check engine light after valve cover and spark plug change
  36. Desperately needs help with Key Fob
  37. 2007 G35 Sedan Fuel Gauge light
  38. sunroof seal bent/damaged
  39. Starter?
  40. 2008 G35 Manual swap
  41. tips to remove stuck on pcv middle hose on valve covers?
  42. Transmission RE5R05A
  43. How to remove alternator plug to remove wire harness for valve cover remoal
  44. 2007 Infiniti g35x coil wire
  45. Car in limp mode after connecting alternator?
  46. Help with A/C not blowing air
  47. Power steering fluid to use?
  48. best tool to remove awkward space clips (atleast for me) on wire harness
  49. Ac compressor shopping help
  50. 2008 g35s - auto transmission cooling line leak
  51. p0430 code again after fresh converter put in
  52. Exhaust rattle at idle on D gear position & A/C on
  53. Tricks to remove terribly rounded 12mm nut on intake manifold?
  54. Locked Doors, Fixing Those Pesky Door Lock Actuators
  55. New LSD in my G35S 6MT
  56. Speedometer hit 0
  57. RPM Dip/bounce when letting off throttle
  58. Radio and ac stay on when car is off
  59. No Sport mode, no manual mode
  60. headlight problems please help
  61. AC Compressor Leak?
  62. Rusted out subframe 2007 g35x HR steel to alluminum?
  63. AC Trouble
  64. Power steering leak
  65. ticking/knocking sound inside the car
  66. Random Coolant “Burp”/Spill.
  67. Trunk not opening (wires look good)
  68. 07 G35 sedan won’t stay on
  69. 2008 G35x Jerkiness in traffic driving me crazy
  70. 2007 G35X needs new front lower control arms
  71. Does my radiator support Bolt on or weld?
  72. Still chasing B1 Fuel Trim issue
  73. remote start on 08 g35 sedan?
  74. Valve Cover leak.... replace just gasket or cover too?
  75. Catch Can Mounting Location?
  76. 08 G35S Budget BBK?
  77. Infiniti G35 2008, Cide P2A00
  78. TSB - ITB17-026b - FUEL TANK IS EXTREMELY DIFFICULT TO FILL
  79. to the guy having problems w/his driver's side window
  80. Switching Motors
  81. P0507 and G freak out after WOT
  82. 2008 infiniti g35 auto transmission problem
  83. Popping noise coming front suspension
  84. Can someone read my logs?
  85. X-drive swap
  86. 07 Infiniti G35 steering rack leak
  87. Car Won't Start No Turn over
  88. slight hesitation on slow take off
  89. Will 2003-2007 g35 radiator fit a infiniti g35x 2008
  90. What is the plastic box on intake tube for?
  91. Rough idle/Fluctuating voltage
  92. Is this part of my headlight supposed to move
  93. 07 G35 sport sedan hearing a light clunk in rear when letting off gas
  94. Water Pump Replacement Mechanic Price Gut Check
  95. Car only starts with a booster pack
  96. 07 G35 sedan sport which exact spark plugs to order
  97. 260k miles with original suspension - time to replace?
  98. Help my car will not shift into park after installing and taking out an aftermarket r
  99. Serpentine belt problem
  100. Help to many Miles ? Mod the car ?
