- Front Poly Bushings
- I want the paddle shift kit for an 07 G35x.
- Top speed pro 1 exhaust
- Help finding the right place for exhaust
- 2008 Infiniti G35 trunk moulding attachments
- Starter Replacement
- Excessive tirewear in the rear
- Cyclist, how do you carry your bikes?
- Transfer Case Bearing and seal
- Manual mode on the AT5 question
- 370Z Typhoon
- 2007 G35x Bose front & rear door speakers
- RPM's on highway, yes I know they are usually high
- TPMS light flashing, blinkers turning on, and beeping noise?
- V36 2jz swap
- 2008 G35X A.C. Clutch compressor gap....
- 07 Sedan Trunk Wont Lock
- Dorman door lock actuator for G35X.. please help!
- Need advice on purchase - G35 overheating
- Windows won't go up!!!
- G35X VDC trips when 1-2 shift.
- Screeching noise when I accelerate
- Back-up camera tail fin assembly
- Replacing Flywheel
- Can a 2008 Infiniti g35s transmission work in a 2008 Infiniti g35x
- Urgent help about clutches!
- Camshaft positioning sensor
- MD Tdx2 on G35x 07 Sedan
- Blown engine ?
- clutch slipping
- Looking for a deep exhaust note
- 08 G35xS just turned 100k! Celebration plans...
- Electrical issue
- Water pump replacement done, now high idle?
- Driving me crazy
- 08 g35 sedan exhaust ?
- Tach flicker
- ICC sensor replacement....sigh. 2007 G35S sedan
- best way to get crackles ??
- Hissing from AC compressor ?!
- Trunk not opening, can't find fuse or relay
- Good & Honest Mechanic in the NY/NJ area for Infiniti G's
- whats a good lowering kit for a 2008 g35 journey
- 08 G35xs sedan Exhaust help?!
- 2008 Infiniti G35 Loc converter and Sub install
- Mileage won't increase.
- 2003 vs 2008 auto transmission difference
- Changed transfer case fluid today
- 2008 g35xs Carbon Fiber diffuser/splitter
- Maintenance suggestions
- HELP - Squeaking from RR wheel
- Where to buy Sport Bumper besides dealership?
- Prospective buyer questions about the engine reliability
- 08' G35X Questions
- Adding factory backup camera w/out factory navigation system
- Previously owned 2007 V36 but wondering about very high mileage issues
- Seat belt buckle came loose?
- Transmission slip
- Quote to repaint trunk, too much?
- Upgrading Rear view mirror
- Fuel Pump fuse/relay
- Brake upgrade
- Getting vibrating/rattling noise from engine?
- Surging Idle and Possible Electrical Issue
- Intermittent engine chatter and fluttering noise
- Pic of under body (front)
- Looking to buy used - Is the galley gasket problem inevitable?
- Weird Sound
- 2007 G35 Sedan Intermittent Overheat Issue
- Abs sensor
- Trim around instrument cluster is squeaking. How do I fix it?
- 2007 G35 Sedan fender removal question
- 6MT Shifter Control Rod
- Steering wheel easier to turn when parked under sun
- 2007 G35x Akebono Question???
- What's this red wire? 2007 G35x Sedan
- 07 g35x oil pressure issue opinion
- Searching for a Part.
- 08 G35 Base - Oil Change Interval
- Too good to be true?
- Is this a good buy?
- Biggest tire size I can run on my car
- Proper ECU reset instructions
- Is there a way to copy FROM the music box to any other media?
- 08 G35x power gains
- center arm rest extension?
- Audio in Aux Mode comes all static like
- 2007 G35 sedan SPORT LIP
- Bought new fob for 08 G35 Sedan but car wont acknowledge key.
- Tires and rims for 2008 G35x AWD Sedan
- Side skirts?
- 2010+ rear bumper on a 2008 g35x sedan
- G35S Fog Light Options?!
- Fuse for auto dimming mirror?
- Error Code P0443
- Help!
- how to replace a blower motor
- Worth getting Bolt Ons for my 08 G35S?
- headlight ballast
