- 2007 G35x Gauge cluster repair/replacement?
- What color code have interior leather of g35 2007?
- Intermittent inteligent key
- Crashed my G35, need advice on what to do with it
- good carbon fiber kits??
- mirror switch box came apart
- lurches and vibrates after 15 minutes
- Door lock freak out
- Shop in NYC that can repair Galley Gaskets?
- Car stalls turning and or going slow
- Helppppppp!!!! Its driving me crazy
- Suspension Revamping (122k miles)
- Theft alarm going off in rain
- sport lip!
- Alternator question
- 2008 g35hr mods
- Opinions
- 2 diffuser?
- C1668 and C1686 - 4WAS/SLIP/VDC lights
- Backup camera install
- Oil in coolant
- Transmission help
- Computer/Power distrubtor? What do you think?
- Stereo removal '08 sedan
- Compressor change help!!
- Crash zone front sensor location
- 2008 G35 Interior Door Trim Replacement/Fix
- Dead gauge cluster
- Will this exhaust fit my 2007 6mt sedan
- Help! Not Sure What Issue Is
- my g37 wont go over 1500rpm and 6mph
- 19x8.5 Squared Fitment for Sedan?
- Rims for 2008 G35
- Carbon Fiber Rear Spoiler
- Front engine noise whine
- What size spacers to run for a drop on stock 18in wheels?
- Pictures of Lowered G35s on 18s? (Preferably Squared Fitment)
- Brake Upgrade? Warped Rotors
- Should I buy?
- Z tube+ K&N drop on filter
- Gear slipping?
- 2008 G35 Sedan P0021 and P0011 Codes Please help!
- G35 - Sedan 07 Long Trip. Seeking advise.
- Compressor Clutch or Radiator Fan DIY
- High power build on a 5at X? Or sell?
- Uprev tune with Seymore
- 07 G35 sedan wheel bearings
- Disconnecting battery did not lose radio presets?
- Z1 Test Pipes
- passenger inner tailight (inner circle) not working
- Heat is too hot
- 4was/slip/vdc
- Test pipes vs. HFC
- Heat not blowing -g35x sedan
- AC Condenser and expansion tube question
- 2007 Infiniti G35 Journey Sedan RCA audio not working
- All
- I need answers asap please!
- muffler or straight pipe??
- Distortion on windshield edges normal?
- Navtool Apple CarPlay - has anybody installed?
- RIP 2007 G35x, Thoughts on what to do next?
- Shift Park issue
- Burnt out gauge cluster and analog clock lights
- 2007 g35x problemmm need help
- Codes on recent purchase. PLEASE HELP!
- Horn Blares When Connecting Battery. Help!
- My car is making a whining noise..?
- Windshield without Shade Band
- New parts from Motordyne for AWD HR
- Washer Fluid Low Alert (Despite being full)
- Urgent! Rear Main Seal Leak. Should I buy it?
- Alternate Size Size
- Differential whine some help please
- Bluetooth?
- Brake light vdc and slip lights are on
- VDC System in AWD Models
- Electrical problems - 2007 g35x - won't start, etc
- 08 hvac compressor broke - advice needed
- 2008 g35x crank sensor
- 2007 G35x engine ground bolt size
- What is this tool in the took kit used for?
- Driver's side door shutting uneven
- Anyone R&R a side sill?
- She's gone
- g35s 2007 overheating quest
- Sport brakes on 08 G35 RWD
- Is Shell 91 Still Good?
- Car won't rev past 1000 rpms?
- What is this?
- Opinions on my parking lights?
- No power to arm rest outlet & RCA/Aux
- 6000k Fog light on 2007 G35
- Opinions?
- Stiff sun visor
- Transmission issues/annoyances
- Remote start suggestions?
- starter problem?
- 07 G35X - Post Throttle Bodies Cleaning Idle Hunt - SOLVED
