View Full Version : G35 Sedan V36 2007- 08
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132
  1. Mode $06 information
  2. Brakes (Rotors/pads) help needed
  3. plenum spacer for v36
  4. Warped Instrument Cluster
  5. Audio & AC control panel
  6. What's the best way to use the screen with an iPhone?
  7. Gearing question/tips
  8. Bike Roof Rack
  9. Tempted to go to the dark side...
  10. Oil and Coolant Mixing - Possible Head Gasket?
  11. Bad Situation with my door!
  12. Warped rotors... again
  13. Glad I have my Elite Warranty
  14. G35 Discussion
  15. Buying a Used 2008 Infiniti G35 Sedan
  16. TPMS frustration
  17. Replacing the G-what is the going value?
  18. New owner of a v36 sedan have some issues
  19. Getting OEM engine air filter online?
  20. 2007 G35 cruising on 9th gear?
  21. Front passenger Clicking noise
  22. spray clearcoat on plastic chrome?
  23. New to me 2008 g35x intro
  24. ?? 5 speed
  25. Sport tires, my experience
  26. Headlight sensor
  27. Vale cover leak fix?
  28. Bicycle in the backseat
  29. Just a couple of questions from a new member...
  30. How much should I expect to pay dealer for TSB, ecu flash for throttle tip in issue?
  31. G35S tire size options
  32. I-Key works intermittenly even in port
  33. Spark plugs
  34. Exterior Mod Suggestions
  35. diffuser paint question
  36. Cold idle 2000 rpm normal?
  37. Question about my key please help!!
  38. i have 2 easy questions if you guys could help
  39. Infiniti OEM Spoilers for $199 or Best Offer Ebay
  40. A hundred thousand kilometre service.
  41. polishing stock aluminum wheels
  42. Identifying a Part (picture)
  43. 2008 G35x rough idle, hesitation and "service engine soon"
  44. AC Service
  45. ssr gt3 vs vossen cv3
  46. Brake Judder issue TSB
  47. Damage to my side fender
  48. Maximum Tire Size
  49. Ball Joint and Lower Control Arm
  50. How to play videos through Navi Screen?
  51. G35 diffuser question
  52. problem: back-up camera display not functioning
  53. Aftermarket rear bumper covers - Bad Idea?
  54. Annoying Problem - Cant find solution
  55. 20" wheels for 07 sedan fitment
  56. AC Compressor Noise Thread
  57. Bluetooth Problem With Phone (Incoming Calls)
  58. Broke something.....idk what it is
  59. anyone have experience with CENTRIC high carbon rotors ??
  60. Suspension squeaks only on hot days
  61. 2008 G35x Sedan Brakes - DIY Exist?
  62. Best spark plugs for MPG
  63. 2007 G35 Sedan Door Weather Stripping (w/ pics)
  64. help! 2007 g35x tune up at 101k
  65. Wiring Fog Light tk Oem Switch
  66. 2008-9 G37 Coupe Rear Bumper = 2008 G35x Sedan
  67. oil access door hanging down 2008 G35x
  68. Windshield Washer Reservoir [with pictures]
  69. '07 G35S wheel sizes
  70. Planning to use my car for a road trip (need opinion)
  71. Weird things happening
  72. mudflap guard bolt
  73. Hit a Huge Rock & Tire Blew Out
  74. Camshaft Crankshaft Sensor Issue - Please Help!
  75. Creaking / Popping Breaks.
  76. Grill on 08 sedan same as 11 sedan?
  77. DIY LED strip HELP!
  78. Regular fuse vs low profile fuse.
  79. Service Engine Soon light!
  80. A/T Shift Knobs 07 sedan!
  81. DIY Taillight Blinking LED's Mod
  82. Rattling noise sounds like a diesel
  83. Extending Elite Warranty
  84. WANTED: Help on removal and install on a few things.
  85. How much drop before I need camber kit?
  86. Collision Help, needed!
  87. 2008 g35 sedan blown engine
  88. Need quick tire help!!
  89. Turning off traction control
  90. 2007 Sedan G35 - Wheels
  91. Difference bettween v36 g35 and g37 navi system
  92. Interior power mirror button
  93. Where do you buy rear spats
  94. Insturment cluster / steering wheel stuck
  95. P0014 p0024
  96. Maintaining my G35, all stock
  97. forgestar fitment
  98. Headlight replacement
  99. adr wheels ( dv-8 )
  100. Engine Fluid Leak? (pics)
