PDA
View Full Version : G35 Sedan V36 2007- 08
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132
  1. Just Picked up Salvage G35
  2. 08 hissing noise
  3. Location of mass air flow sensor
  4. Help me find out where water is coming from
  5. PLEASE HELP !!!!! G35x sedan not starting
  6. 2008 G35x HFC Hesitation
  7. Mods at 186K miles worth it?
  8. Mods at high mileage worth it?
  9. Frame issues with engine mount replacement
  10. Tire size will it fit
  11. HomeLink Rear View Mirror from newer model Nissan/Infiniti?
  12. Looking to have a tsb done on my 07 hr g35x
  13. slight hesitation at take off
  14. SOLVED Vibrations at highway speeds
  15. stiff brake pedal when car is off
  16. 08 g35 air intake question
  17. Important question about this G35xS
  18. Weird stutter/hiccup problem. Please read and small reward
  19. Snow ='s fun! in a 35X
  20. G35 power issue EVO
  21. Passenger heated seat not working
  22. 07 g35s
  23. DIY - $2 Tablet Mount (Holds laptops and cell phones too)
  24. Coolant on rack and pinion
  25. 08x Radiator Fan always running
  26. V36 VQ35HR thermostat install - Warning!!!
  27. Steering Wheel Wobble
  28. Might need new BCM, keys, power locks, cruise doesn't work.
  29. Window switch
  30. Infiniti g35x 2008 key light
  31. High pitched vibrating sound when above 3k rpm
  32. 08 g35x sedan - Reverse light wiring
  33. Aftermarket Headlights
  34. Turning vibration
  35. Power Steering Blown
  36. Car sometimes does not start and stalls
  37. New to the G life!
  38. Help me decide
  39. new battery today...
  40. Need help. Cosmetic Exterior
  41. HELP! My daily has hissing and soft brake pedal...
  42. Power mods
  43. Car won’t start...need some insight
  44. Need advice on buying a car
  45. DIY: How to Replace Control Arms and Ball Joints, Tie Rods, Stabilizer Links
  46. Coolant Temp Seems High
  47. TPMS Problem
  48. Engine behaviour
  49. Battery light on, alt tests fine off car, anyone know what this is?
  50. After market resonators
  51. G37 Parts
  52. Window problem
  53. 07 G35X Rear break pads and rotors replacement
  54. Low RPM while driving
  55. Emergency please help headlights not working
  56. Blinkers Please [HELP]
  57. Window problems
  58. Car won’t start.. 2007 G35
  59. Help with standing burnout 08 G35xS
  60. All lights on dash are on after changing rear caliper
  61. Coolant issues
  62. Cold start: low, rough idle then is normal after a few seconds
  63. What screws are these?
  64. Cooling Fan Issue - Not The Fan Control Module
  65. P1550 code: Battery current sensor
  66. Overheating when A/C is on
  67. Keyfob stopped working.
  68. Automatic shifter needs bumped to put into Park
  69. G35 V36 Bodykit
  70. Valve body help
  71. Mysterious Coolant Leak?
  72. Radiator Change with Mileage/Age
  73. Should I Do a oil flush codes P0014 and P1815
  74. Finally found my cooling issue
  75. Exhaust questions
  76. A/C Compressor Clutch intermittent
  77. Driver window button broken
  78. what milage should I change out my stock radiator?
  79. where to buy red silcone radiator hoses?
  80. Story time
  81. Surging RPM when cold
  82. Coolant in transmission.
  83. Kyb strut top bolt question
  84. Hesitation in throttle
  85. Clean look options for running cables in the interior of the car
  86. 07 G35X sedan VR36 with VQ35HR and am getting P0024 cam sensor and P0171 bank 1 lean
  87. Burn wire / shirt from IPDM
  88. Driver Side Sensor Wiring Help
  89. no oil pressure at idle, 222K miles, advice?
  90. Car Wont Start. Dash lights all lights come on.
  91. 2008 G35X Fog Light Help
  92. Bumper!!!!
  93. 08 G35 Sedan
  94. 200k last weekend. Please excuse the humble brag
  95. Windshield trim on top
  96. VQ35HR Oil Consumption
  97. Exhaust header - checking
  98. Weird issue
  99. Dead alternator
  100. 07 Sedan Overheating.
