PDA
View Full Version : Wheels & Tires
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167
  1. g37 wheels
  2. Wheel studs keep breaking
  3. 5x120 possible?
  4. powder coating aftermarket rims?
  5. Need advice on which Rims will look best and what offsets!
  6. Rubbing issues
  7. Constant grinding noise
  8. Tire maintenance?
  9. Can you identify this wheel?
  10. Tread Depot Kumho Tire Promotion
  11. Cooper RS3-A Tires..I like it a-lot
  12. need advices.
  13. Hankook Ventus V12 Evo - score!
  14. Neal Out Until Dec 2nd
  15. Rim/tire spec question
  16. Camber Wear on Rear winter tires, should I buy?
  17. Changing from 18" OEM wheels to 19" OEM Rays
  18. Offset issue and Brembos are rubbing
  19. First Gen Sedan 20x8 +20 and 20x10 +20
  20. wheel spacer size? - OEM suspension and Rays
  21. Winter Tire Help!!
  22. newbie
  23. *LIMITED EDITION* VarrsToen ES2 18" Machined Finish
  24. Staggered tires on OEM 18's?
  25. TIRE size help
  26. Can Anyone ID These Wheels?
  27. Help with choosing tires/wheel for new setup
  28. Neo chrome wheels
  29. Will 20x10 or 19x10's square setup fit rolled g35 fenders
  30. G37S rims on G35?
  31. Alignment Issues
  32. offset question
  33. Identify these wheels please...Love 'em...
  34. h&r wheel spacer question?
  35. Are these OEM 19" Rays legit? [PICS]
  36. Deep dish rims
  37. Square Setup with 20x8.5, +20?
  38. front calipers wont let rim fit
  39. What do you guys think of 18" rims with lips?
  40. max tires for staggered 18x9 and 18x10
  41. LMs or RSs on a g35 coupe?
  42. Recommended wheel spacer size for stock 18'?
  43. Winter Tire and Wheel Reminder
  44. Wheel spacers on an 05 G35 Coupe 19" stock rims
  45. Help me choose new rim color!
  46. Wheel spacer size??
  47. Do I need all season/winter tires?
  48. 20 x 11 Rims
  49. 03-07 Lug Pattern
  50. Question about wheel fitment
  51. camber + alignment problem
  52. 18x9.5 +12mm offset coupe front fitment question
  53. Help my front stop rubbing!
  54. Winter Wheels & Tires Special
  55. Factory 18's for 2007 G35X
  56. Studs change! HELP!
  57. Where to find custom rims??
  58. Inner Center Tire Wear
  59. Wheel Repair
  60. Tires '05 G35
  61. How dangerous can this be??
  62. Inner Tire Wear
  63. TPMS Light Still Comes on After Reset?
  64. What size tire do i run with 19x11?
  65. Powder coat vs paint OEM wheels
  66. Need to borrow a varrstoen wheel lock asap, in 760 Socal
  67. 275/30/20 vs 255/35/20 fitment question
  68. PHOTOS! GroundForce GF8 on 2 - EVO X, 19x10.5 all around and 19x9.5 square !
  69. OEM Chrome rims causing air pressure loss?
  70. 2006 G35 coupe winter rims and tires
  71. Yokohama Avid Envigors Premature Dry Rot
  72. 245/50/19 winter tires on G35 Coupe?
  73. Need help choosing tires.Can I use a different tire height/width than is recommended?
  74. 19x11 + 12 and 19x9.5 + 22 g35 coupe, fitment?
  75. opinions on painted stock wheels
  76. Work wheels vs Weds Bazreia wheels
  77. Opinions on Rims/Tires?
  78. Blue Varrstoen ES2's on DG G35 Coupe, should i do it?
  79. Any experience with TR Motorsport wheels?
  80. Do these wheels fit on my G?
  81. What size rims would be good for a 1" to 1.5" drop?
  82. Corrosion? on my Rays What can I do?
  83. Correct Lug Nuts for OEM 370z Rays
  84. Xxr 527
  85. 2008 G35X TPMS air leak
  86. Need wheel advice, Eurotek 02
  87. Upgrading to 19" rays
  88. Noise when accelerating only.
  89. Wider wheels with a stock look
  90. Wheel and tire fitment?
  91. EVO X MR Wheels on a G35 (WITH PICS)
  92. Non Staggered Setup, VDC issue?
  93. Professional wheel repair= OEM quality?
  94. Recommended Tire Size for Double Staggered Nismo Track Edition on G35 Coupe
  95. Looking for input on tire width for 20" Work VS-XX
  96. TPMS Sensor Part number??
  97. Rear tire size options - 19x9.5 (30 or 40offset)
  98. clearance question
  99. Pretty Good Tire Offset\Size calculator
  100. Bent / damaged / dented wheel - How do I tell???
