- Anyone running Braum Racing Harnesses
- Quick quesion
- 05 Coupe, VDC off, Slip, loss of power
- VVT Solenoid Gasket
- Muffler or Resonator delete?
- Custom Fiberglass Sub Enclosure (Coupe)
- We are buying Infiniti G35 with VQ35DE
- Exhaust for G35s?
- Can you tell if my control arm bushing is bad?
- Muffler
- Need a Radiator
- Is Hitachi a good brand for a fuel pump sending unit?
- Problem after changing Spark Plugs, Please help
- Cai-muffler delete-5/16 plenum spacer
- Code C1130 and getting bad O2 sensor readings
- Dropped object into intake valve - what next?
- Trunk leaking from speaker
- Steering Shuddering
- What oil is best?
- Cd009?
- Switching from 2005 OEM G coupe headlights to 2006 projectors. Questions below.
- Looking for Syncros for my 6mt
- Air bag light after racing seat install
- Radiator Support cracked tab
- At what mileage did the leather tear on your driver seat?
- 2nd Gear GRINDS after transmission oil change!!
- Lower plenum on rev up?
- Noise coming from motor/tranny
- G35 shock and strut question
- Fuel pump not going back inside...
- Can someone confirm from me if this is the right sending unit for a 03 coupe?
- socal Tuning: saul-nismo-knights or Church Automotive
- RE-SHELL/ENGINE SWAP Questions
- G35 Owners: What is a Fair Value For an '05 Coupe G35 with 70K Miles In California?
- My progress after one year
- Limp Mode HELPPPP
- Fiberglassmafia - Sponsorship - 3 Spots for G35
- How do I remove the exterior door moldings
- do all G's have oil burning problems?
- G35 2006 custom guage face
- what options do i have
- Dyno Numbers
- Dashboard clock/climate bezel/panel
- What is this thing?
- Multiple tpms codes
- Throttle Body help
- Another P0305 problem is this a sign of coil?
- Please help with my 05 coupe!!
- Should I fix my totaled G?
- Upgrade suggestions
- G-35 coupe can I use an sedan replacement engine?
- Anyone have any experience with the TS Style Diffuser from Duraflex?
- g35 seat stuck
- g35 coupe how many miles?
- q60
- Z1 Motorsports Media
- Need Help! Spoiler Brake Light Replacement.
- G35 Replacement Window Part
- Maximum negative temperature reading on the dash?
- jdm double din kit question
- Misfire in Cylinder 6. Any ideas?
- Should I buy a g35 coupe?
- MaxSpeedingRods Coilovers on a g35 2006 - Experimenting
- Gas tank constant shutting off fuel
- Sunroof help please
- Cel
- G35 Re-shell - Few Questions!
- What is this harness for?
- 2008 front seats replacing 2004 seats?
- My First G35
- I am only getting 12 MPG
- How to Adjust the headlights without taking bumper/front apart ?
- Temp Gauge
- help
- Which test pipes are these?
- headlight confusion
- Squeaking coming from front end when I let off the brakes
- 05 Coupe headlights
- Help! idk whats wrong with my g.
- Only VDC light on after Nismo cluster install
- MREV2 Troubles
- Engine ticking noise passenger side
- Reliable G mechanic in northern NJ?-New G owner
- My G35 idles high.....
- Flickering Display
- Where can I buy 06-07 headlights?
- NEW HERE!! Just bought...(pics)
- Overheating
- Good News and bad news
- Im new here
- P0301 cylinder 1 misfire repair process
- Battery problems, any similar stories?
- 135k mile oil change
- Automatic Trans Fluid '03 Coupe
- Spark Plug Replacement
- Building a wide body kit
- G35 coupe fender help please!!
- unboxing Motordyne TDX2 exhaust for the g35 coupe.
- General Knowledge
- Car is going into Limp mode. Need help!!
