- New to the community
- Car has no power and stalls out when put in drive
- G35 dimensions for a possible swap
- Cannot figure out the problem - pls help
- ‘03 6 speed coupe stuck in gear. PLEASE HELP!
- Maf
- My car is stuck revving on its own at 2k rpms?????
- No illumination from tails unless breaks are depressed.
- Car stalled out at 3K RPM, cranks but won’t start
- Fuel Gauge inaccurate
- pop or thunk when quickly tirn steering wheel to left
- Had a major grinding issue
- Grounds
- Where to buy?
- Bad performance and rough idle when fully warmed up engine
- Spec-D projector headlight adjustment
- What should I fix first to make my car “safe for the street”
- Weird cam timing?!
- What is this called on my g35?
- What would you do? New engine, or let it go?
- 06 G35 Sunroof only opens 25%
- The infamous fuel gauge problem; soldering help?
- Bad ignition switch start no turn off.
- Coolant leak from coming down the driver side of my engine?
- Headlight issue
- Gear shifter trim plate / panel - is this it?
- Some fluid leaking next to driver wheel
- What should I change when starting a car that's been sitting for two years?
- Anyone have the box 2004 G35coupe Rear Coil
- G35 rusted undercarriage
- 2004 G35 Rear Coil OEM After Market
- Rear Bumpers
- PAC ROEM-NIS2 or PAC LP7-4 L.O.C.
- Front end vibration
- Rev Up FSM?
- Interior spray paint color for black center console
- 03 G35 Coupe Speedometer and P1136
- Please help!
- Stock Infiniti QX50/QX60 20" rims/wheels for G35 Coupe ?
- Car will not shut off with key out of ignition.
- LS swapped G35
- Oil analysis of recent purchase
- Shots Fired, But I Still Want That G
- Overheating
- Aux Interface by Grom Audio (satellite)
- Bolts for attaching grille to body correctly
- No start and I’m lost
- 04 g35 driver side headlight not working
- IPDM Wire Harness Photo Request
- 19" oem rays fitment advice needed
- Just bought an 03 G35 stuck in limp mode
- Radiator support question.
- G35 Grille
- 06 g35 overheating
- 06 G35 clutch noise problems!
- Rebuild + Twin Turbo Project
- Hesitation/jerking at WOT.
- Crank no start AND no fuel pump priming
- Trouble with wiring axxess aswc-1 steering wheel controls
- Weird grinding noise?
- Need 2 front tires..?
- Need help or advice on coilovers/fitment
- 05 G35 Coupe Misfire / Hesitation at Idle
- 2004 g35 auto coupe electrical issue crank no start please help ‼️‼️‼️‼️‼️‼️‼️‼️‼️
- 2004 g35 coupe pin 101
- What to do with my old coupe?
- Cam Sensors on REVUP
- P1757 A/T FR/B Solenoid Valve Circuit Malfunction
- Good G35 Mechanic In Richmond Virginia
- Driver side front window adjustment
- Engine cover for 03 g35 coupe
- 2003 g35 60k miles Rusted Beyond Repair?
- Stranded on hwy need advice asap
- G35 aftermarket carpet on ebay?
- Question: Can I fit 05 front fenders onto an 07 coupe?
- Time to say goodbye to my 07 coupe!
- What idle do your g35 6mt sit at warmed up?
- Need help getting calipers
- G35 coupe vs G37 coupe.
- Scanner
- ODB2 No Power After Engine Swap (DE non-revup to DE non-revup)
- HELP! 03 G35 Coupe Starts and Turns off immediately
- VDC Problems
- 2006 g35 momentarily sputtering on cold drives
- M Style Spoiler for 06 G35 Coupe
- 2007 G35 Coupe 6MT Suspension
- Honest mechanic in North Jersey area?
- Whose car gents and ladies?
- Paddle shifters for 05 g35 coupe
- How many 2004 my G35 Coupe performance 5AT still worth
- Please read all of this if you like cars
- Thoughts on Nismo Suspension Parts?
- Momentum Performance Single Turbo Kit
- No Dash or Instruments
- Harness
- Would you buy this G35?
- Swapped engine 2005 G35
- Another P0300 victim
- DIY paint fix color match
- Same song different Story
