- g35 coilover question
- 06 Coupe seats in 03 coupe
- 03 G35 Sedan no start possible wet fuse box
- Lowering???
- Lowering???
- Brakes locking up
- Random Cylinder 1 Misfire
- G35 coupe 1004 Camsensor
- 235/40/18 with 245/40/18
- Non-RevUp lower plenum on RevUp w spacer?
- Running too rich? FML
- P0327 and p0011. Car stalls while making a turn
- P0327 and p0011. Car stores while making a turn
- A knock or bad timing chain rails or w.e it’s called? Please help
- Where to get a reliable used engine?
- NJ/NY Tune Shop?
- G35 Exterior door handle lock cover replacement
- Exhaust Pipes
- 03 valve cover replacement
- 2004 G35 Help I have PO 300 and PO 327
- Alignment prior to Lowering?
- Clutch & Flywheel replacement
- Exhaust cam sprockets?
- Sell or Fix my 05 G35 coupe
- A/C & Heat
- 2005 g35 coupe Headlight wiring harness
- Cold Air intake
- Turboing v35
- What is this?
- Differential Slipping After Intake Upgrade
- Help With feed line
- Timing Belt or Chain?
- Odometer screen malfunctioning and doesn't read. Help!
- 03 Coupe Fuel Pump
- Low compression
- Exhaust setups
- Full size Spare?
- P0300 code after removing upper plenum
- What does the spoiler signify on coupes?
- Radiator Fan Compatibility
- Stupid Valve Cover Question
- Stupid ball joint question
- Y pipe leak???
- best place for door actuator kits
- 06 G35 Coupe - HELP!
- Vdc, slip, abs won’t turn off
- Help me Decide on wheels! 19" Rays OR XXR 521 black?
- Going to look at a used G35 today.
- Ready for Spring - Whos with me?
- OBD/CEL -unable to read codes!
- Bought a Crashed G35 - Auction Rebuild
- Undercarriage Splash Shield / Shroud / Tray / for the whole underbody?
- Please help me figure out what this wire is!
- G35 red interior
- Driver seat getting torn up
- Sunroof stopped working?
- Is $5,300 a good deal on this 6mt coupe with 147k?
- 2006 G35 Coupe no start
- Crashed my 2007 G35 Coupe
- Part of door panel peeling off
- Lights on the dash and a/c & heat not working
- Car just shut off while driving. Cranks but won’t start.
- Six-speed manual hesitation when punching the gas
- Running Perfect Now Won't Start
- New Oil Catch Can Day for the G35
- ignition condenser?
- cant get cruise control or horn to work
- 2003 G35 Sedan
- Spun out and hit a curb, now the car wont drive straight and gets wobbly
- Shudder with WOT. NO CEL
- New to owning a G, need help
- The BEST Junkyard Find Today!!!
- Decent quality oem style coupe rear spoiler? 03-07
- Rev up to de
- Backup Camera Recommendation?
- 2jz/1jz engine swap.
- Brake lights not working.
- Some help honestly please!
- My car will not start with the mechanical key. Please help
- Body work in Toronto/GTA Canada
- How much is the average to replace all suspension components plus manual ransmission?
- 2006 get coupe
- G35 coupe replica poly front vis racing or outcast garage????
- 2004 Coupe No Start, No Clicking, Battery Good, Starter Good
- My car cranks but there's a clunking sound coming from the transmission
- Tail lights wont turn off NOT brake lights!
- Coolant hose
- Missing hose.
- Engine Tune necessary?
- Fitting Nismo S-Tune Exhaust on 04 Coupe
- Low Idle problem?
- Cam sensor
- Rattle During Acceleration 2-3k RPM
- Code p1757
- Those two stubborn bolts that hold the condensor to the radiator
- Driver's seat is loose ('04 coupe)
- PLEASE HELP G35 making loud rattle noise
- upper oil pan fatigue fractures?
- Exhaust question
- Codes P2122 P2138 P1228
