- headlight tabs...fix or replace?
- Something Burning?
- Front end creaking while driving
- Another buyer need advice.
- Front Grille issues .. stupidd mann
- Help!
- Rounded nut on pumpkin swap! Help!
- How to Make...
- Just picked up a new g what should i do first ?
- Just got a new G35 what should i do first ??!?!?
- DIY or just pay someone?
- How necessary is a tune?
- Tokico D-Specs no go for 6MT
- Hey
- how much will it cost to install 1" lowering springs?
- Window motor is possessed!
- What is the best wheels color for the dark blue G?
- Bye baby.....
- Offsets..
- a/c clutch always engaging *help*
- Lower back support in seat? Best way to help posture?
- Quick question about a particular exhaust...
- "service engine soon" =x
- N1 lip installed =)
- Broken Headlight Tabs?
- Buying a new G
- Offset without fender roll
- Hi, about the side mirror
- Boston ?
- Car Turns off on its own please help!
- NEW g35 owner!
- 2006 G35 coupe...sport suspension package?
- Hello !!! New to the Forum
- Security System
- For my SoCal peoples...Where do you go to get your car serviced?
- why did i lose torque?
- How long should it take my tein stech springs to settle on my coupe??
- in SoCal till the 26th, and shows?
- repainting brembo brake calipers
- OC question...
- Faster
- one side lower than other?
- scraping problemsssss
- Dropped G's
- Looking to get IPL G37 coupe rims
- new to socal
- clear corners too bright?
- Stillen Intake g35 installation help
- Wheel options... which one?
- New exhaust
- bumpy idle, needle not moving.
- Maintenance Question
- All lights turn on when starting car, car doesn't start.
- Auto glass fix...
- new g35
- need some wheel advice...
- 68 degrees outside. 100+ degrees inside the car wth...
- Anyone have a Black roof w/ roof spoiler?
- Z Tube
- Front tire wear and service
- Test Pipes in Cali
- 255/45/18 on rear stock 18's?
- Need suggestions on a drop!!!!!
- vertini wheels
- Staggered Wheel setup...
- independent fogs
- too good to be true?
- Blacked Out Grille Almost Complete
- Need help picking out a G35 coupe
- thoughts on what I was wanting to do with my g35
- Purple Fluid Leak?
- mysterious clicking noise with front suspension. please help!
- Did rear arms and still cant get the camber in
- Any G's norcal (San Francisco) out there?
- xxr 521 20x8.5 +32(F) & 20x10.5r +30 (R)
- True Dual Exhausts With Rear Steering
- Fast Intentions Exhaust Installed!!!!
- 2004 6mt coupe OC issues.
- rattling sound when idle, goes away with clutch pressed
- Seat Gone Psycho
- How to go about doing this. GTR SEAT
- what do you guys think about these wheels?
- PCV Socket Size
- front end destroyed need parts
- Plenum gasket question
- Blown Motor... Suggestions?
- Performance parts question
- Vibe/rumble strip feel @ 50-60mph
- Coupe bumper suggestions?
- H&R Sport Springs Raised Car Over an Inch?
- New proud owner!!
- Different mods to do to you cubby
- Are all G35s like this?
- n00b bout to school you peoples...grill removal
- HELP PLEASE! car wont crank
- Transmission Oil Pan
- Frustration with Dealership
- Hi guys need help over here
- I have a P0300 fault code
- Need opinions on wheels size and color.
