- need help with buying a knock sensor
- Around how much could this sell for
- Colder spark plugs
- Money pit
- ABS/ABLS Problem?
- complete confused
- Help! Car dies while driving?
- Replacing clutch fluid - doable as 1 man job?
- 04 g35 coupe satellite radio hardware
- Exhaust System Recommendations and ideas
- Stock wheels, good fitment?
- Is it possible?
- Need MAJOR help with G35
- Code P1078
- Reading Dipstick
- Custom headlights Questions
- Acceleration Issue
- Passenger Side Cooling Fan not working
- rev up camshafts
- Starter relay fuse and U1000 code
- Wiring For Reverse Lights And Neutral Position Sensor
- 2003 Infiniti G35 Sedan TCM PROBLEMS! CODE P1757
- Invidia Gemini differences 350z vs. G35
- Has anyone done their own painting obsidian black
- Weird noise after sandwichplate installation
- G35 clutch pedal
- Vibrant resonator 1792 less rasp?
- SUPER rough startup 04 DE.
- G35 coupe
- My G35 rpms drop during hard accelerations ??
- 04 G35 Coupe Undo muffler.
- Loss of power help!
- Z1 Ecu Mail-in Service
- Engine swap for my g35 coupe
- 2004 Coupe 6MT maintenance and fixes
- Crank but no start after engine swap
- Wiper fluid doesn't come out
- Breaks lock up whilst barely applying pressure.
- Abs, vdc off, slip lights
- VDC and Slip strange problem
- Engine stopped while driving. Cranks but won't start
- Verdict in on my 05 G35 with 36000
- What should I check before a long trip? 2004 G35 6MT
- Painted my headlights black
- Canadian Projectors on USDM Coupe
- Did they ever make the '03 coupe with side molding?
- Internal Work
- G35 overheating and in limp mode after radiator change
- Why does my 03 G35 start sputtering during acceleration
- g35 weird tranny noise
- New G35 Owner with questions.
- Weird noise when started cold
- Rear radius rods... spring loaded?
- 5/16 MD intake spacer CEL
- What is the earlier manufacture date for the G35?
- Spring 2020 Mods - log / photo gallery
- Reputable Shops in Greensboro, NC
- Slip and VDC off comes on
- 2007 Infiniti G35 Sedan not starting
- 2005 Valve cover replacement and P0345 code
- Error Code P0011?
- Exhausts and lateral bracing
- 2005 G35 Coupe 1/4 Glass Removal
- Changing Valve covers
- '05 G35 coupe only 36k miles P1815 A/T See pic
- Question about service
- Lowered my v35 with Eibach Pro kit
- 2003 g35 4m problem
- Looking for new front fenders for my G?
- Which 3.7 lsd diff will fit onto my 06 g35 coupe AT
- Gauge Cluster Overlay / Change ?? 05-07?
- '05 G35 coupe only 35k miles A/T issue, help!
- G35 Coupe window alignment
- G35 coupe/Te37 sl sizing questions
- New to this. Advice on my 2004 g35
- Will a aftermarket g35 front bumper fit inside my g35 coupe?
- 2005 G35 Coupe Starting Issues
- 5at to 6at
- GTM Pulley
- G35 with 350z nose..
- Cam sensor (passenger side)
- Thoughts/Opinions on Squared set of Ray Forged Wheels (4x Rear)
- G35 2005 Wiring Help
- Waddup guys
- WTF IS THIS SOUND https://www.youtube.com/watch?v=n2oxZy6yYvw&feature=youtu.be
- need to get g35 coupe back to OEM shocks
- Help please weird noise in neutral
- Proper clutch adjustment
- Vizrez bumper fitment issues
- Car won't start after sitting for a day
- GT3 Bumper Install
- Suspension wobble after coilover install
- Positive battery terminal smoking hot?
- Seat covers
- Tuning with 180k Miles
- 6spd wont reverse?
- Conflicting Info- P1078 & P0462
- Why are Infinity G35 coupes so cheap?
- Y pipe assistance
