- Happy To Be Apart Of Family and Auto Tran G35 In Snow Question
- headlights
- DIY Window grease streak fix
- Clutch Pedal Stuck... Really Worried.
- Painting Emblems Green/Black
- Tranny went out...is it even worth it?!
- Anyone running niche vicenza (m153) on their G?
- New 06-07 OEM headlights?
- Anyone have experience shipping a lowered car?
- Repair estimate?
- Found a thing or two in Center Console
- Air Diversion Panel
- New to Jacksonville, FL - Need my Coupe Looked at
- Gap between fender and bumper normal?
- want some opinions......
- VQ revup rebuild question.
- Painting stock coupe rims need advice!!
- G35 sunroof tilted off axis
- 2003 g35 coupe headlight bulbs
- Debadging 2005 G35 Coupe with 100K+ miles
- Front Bumper Rplcmt - Need Advice
- Windshield Wipers
- Sluggish G?
- What maintenance should be done on my G35?
- What if this board had a live chat room? (also i do have a ques about bearings)
- Engine block casting number
- Help: Is this VIN sticker fake?
- Check out the Air-Rat intake!
- Timing Chain or Chain Tensioner, when to replace
- Need your help guys on finding 05 passenger seat switch
- Window down with switch, but not with door
- Price for lip painting?
- What type of hood is this?
- Headlight Replacement
- Performance Tune Ups
- Drivers side radiator fan bit the dust...
- Airbag Module
- Outer tie rods FLIP FLOPPED!
- G35 auto trans wont release the key in parking
- Tail light fuse
- Fast Intentions non-resonated test pipes
- Tail lights staying on!
- Oil consumption
- 04 G35 coupe start up issue.
- OEM Double Din Stereo Kit for '07 Coupe Without Navigation
- Rohana rc10
- G35 Trunk Wiring Harness help
- I messed up, any ideas? can't open door...
- Seeking Expert Advice - You know who you are!
- Help: car jerking
- VDC off, Brake, and Slip lights all illuminate?
- Gas meter screwed up
- How to remove the coupe grille?
- Cost of replacing front struts?
- clock and center console buttons not lighting up
- Is it possible to bend the frame of your car from scraping too hard?
- windows and locks stopped working
- Get underbody
- Stranded again (new posts) no start
- Steering Issue!!!!
- 06 coupe driver side window
- Genisis coupe spoiler on G35
- Engine off of a 2006 350z MT
- 2005 Coupe winter tires?
- What am I scraping under my car?...
- Keyless remote will not program!
- Acceleration Rattle? 03 Coupe
- 16 inch rims
- 03 coupe p1769 question
- New-er 3rd brake light help request
- Missing first gear
- Shockwave Motordyne TDX2
- Work equip question
- Keyhole cover - how to reattach or part #?
- Looking for a little history help
- 03-04 coupe and sedan dash interchangable ??
- Question about repair costs.
- changing throttle bottle
- Front Bumper Help
- 30-40+ HP gain with this setup? No exhaust?
- G35 master clyinder hard line
- Anyone know where to get this side marker?
- Fixing Various Issues on My Coupe - Cost?
- looking to get 18' or 19' wheels
- O2 sensor confusion
- Question regarding torque and my transmission!
- The most awkward/ weird starting issue on my 04 coupe MT
- Chip (AT) any recommendations?
- Auto Up Window Feature Not working !!
- another one of those Jack threads...
- Pls help
- Are the Interior door panels the same throughout all years ?
- 05 g35 overheating!!
- Car dying. Need confirmation . Vdc , brake, slip lights plus battery dead
- 04 Coupe - Windows Loose?
- Engine shuts off
- New Car!
- Aftermarket Projector headlight DLR-LED Headlights Angle Eye
- Lift points not jack points question
- Intake gaskets
