- G Experts, what's my trade value?
- Replacing eng this weekend
- Best engine oil to run while supercharged?
- lock and unlock in the BCM
- Lowering springs
- Tuning question.
- Need Engine for 2004 G35 Coupe
- Healthy engine compression?
- 5AT to 6MT Swap - Need IPDM wiring input
- Bad ECU on my 2004 G35 coupe
- Front right tire won't rotate.
- Help with part numbers...
- Super newb question
- My will not start periodically at times.
- Cracked Rocker Panel Protectors
- Cel flashing vdc off light and slip light on
- Rear license plate removal
- 2004 G35 coupe problems
- Can’t remove bumper.Anyone know what’s the problem?
- new to here and have a electrical question
- Does anyone’s know what this is and why it’s overflowing?
- 03 g35 looking to upgrade to 06 headlights
- Cold weather starting vibration
- Back end vibrating like no tom
- Short Shifting in Most AT/MT Converts
- cluster lighting up like a Christmas tree
- How to remove Front and Rear Bumper
- send lock signal midnight, every night?
- brand new buy
- Quietest Test Pipes
- Turbo Oil Drain Pain - Low mount turbos
- Double din cubby
- [07 G35 Coupe 6MT] 2nd gear grinding/clunkiness?
- Car problems after new clutch
- Car shakes upon braking - Replaced rotors, same thing
- Stripped Air Bleeder Screw
- Front Airbag Sensor Compatibility
- Test Pipes
- Lights won’t turn off
- ABS,SLIP, VDC on, along with buzzing noise
- Clock issue
- New to the forum
- Want to cheaply replace aftermarket HIDs possibly
- Scratching noise on initial throttle
- Cruise Control "Set"
- Cruise Control button relocation
- I have all new suspension parts and car still has a bumpy ride
- Where to buy sensor replacements
- NOT WORKING: Dome/Door Lights, Steering Column, Power Seats
- Need subframe brace bar bolts
- '03 Coupe Spoiler light Dissassembly
- Replaced o rings on cam sensors now vdc light on
- 2003 G35 went dark
- Throttle body issue? RPMs hesitate before falling
- 2006 G35 coupe 5AT downshift on its own?
- Spoke wheel suggestions
- parts swap
- Tunnel Shots
- 04 G35 build
- gas cap crazy
- Question About Tail-lights.
- 2004 auto G35 coupe crank HP
- 03 wont start
- Squeak in engine compartment does not increase with engine speed
- Burping coolant system question
- 2003 Coupe Mechanical or Electronic clutch fan? How to tell?
- Radiator cap question after installing new radiator
- Need a recommendation for a possible engine swap/rebuild?
- Tire issue? Or no issue?
- G35 COUPLE things to know?
- 5AT manual-mode/failsafe
- Average cost
- How many fuel pressure dampers?
- Inside Door piece
- Longevity of timing chain tensioners
- HNR Lowering Springs
- Black Friday/Cyber Monday 2017 - Deals Start Now!
- Inteligant key button replace or need new handle?
- Braking system
- Advice for for my diamond 2004 G35 coupe
- CA Legacy Plates on a White G35?
- What part is this
- my car wont start
- Engine replacement questions
- How to remove G35 Coupe door?
- Passenger headlight
- 18in rims on 2006 Infiniti G35 2006 Coupe?
- random stalling
- White smoke coming from underneath car
- Stolen Key Fob
- Weird idle with nwp throttle
- Help
- Front drivers headlight
- Tiptronic Seems to be downshifting on its own.
- Fuse question
- 2004 G35 Skid Plates
- P0500 Code Need a solution
- G35 coupe not able to shift
- Clunking/metallic sound from rear diff area
- A/c question
