View Full Version : Audio, Video & Electronics
  1. Whats needed for a Double Din audio install?
  2. Any interest in DIY for running new speaker wire to the doors?
  3. Need help on Double DIN Choice!
  4. Buttkicker Silent Subwoofer
  5. FM Radio Interference after installing Invisicord and Escort Detector
  6. Need help adding sub to 07 G35S w/ prem/tech/nav package
  7. Anyone think the 2k5/6 Bose sounds better than the 2k7/8/9 Bose?
  8. Value added of Navigation
  9. CD changer swap possible?
  10. PAC Steering Wheel Interface Install Question - Connector Type?
  11. Post FIBERGLASS/fiberglassing Pics of installs!
  12. How do I use MP3 Option on Bose?
  13. BOSE AMP turns on after Volume is at 20.
  14. Opinions Needed: Which 6-1/2 Speaker Set-up to Use?
  15. 2004 Sedan w/bose DD help!
  16. 03-04 JDM Double Din?
  17. PAC steering wheel control
  18. JDM vs Metra (HELP)
  19. PXAMG Setting's Question
  20. Best Head Unit available NOW?
  21. Generation 1 Navigation Controls
  22. Better place to tap remote turn-on wire?
  23. Altima Touchscreen Fit on G sedan
  24. dvd navigation europe disc
  25. Navigation Istallation for an 06 G35 Coupe
  26. Locks are actting up!
  27. Picture of the Navigation v7.4 DVD?
  28. so what exactly do i need for a DD install in an '06 with Bose?
  29. iPhone 3G Adapter Options
  30. Riverside has double din kits with dual button on ebay again!!!
  31. Getting mixed signals about installing deck. Please help.
  32. Just bought my g35, need opinion on: 1.ipod/hd radio, 2.dvd/navigation, 3.bluetooth
  33. Antenna and wire harness adapters
  34. Question about radar detector
  35. Help with Speaker and Power wire interference
  36. Is my amp enough for this DVC Sub?
  37. Installing Satellite radio
  38. 06 dd kit
  39. What to do with audio problem
  40. PAC AAI-NIS2 or PXAMG ???
  41. Which size speaker spacers?
  42. ipod question
  43. My stock Radio ?
  44. 06 G35x Sedan ipod install...major frustrations
  45. NEEDED-05 Factory Nav Harnesses
  46. Sound systerm advice
  47. Replacement stereo recommendations?
  48. CD Player: CHECK DISK!!
  49. Speakers for heavy metal
  50. left door speaker/tweeter no noise
  51. Advantages to upgrading your battery?
  52. where can I purchase a JDM double din kit + AC controller
  53. left door speaker/tweeter stopped working ???
  54. some good songs to test your system?
  55. how can i get my steering controls to work with my alpine cda-9833?
  56. will the PAC AAi NIS2 work with my 07 g35?
  57. HELP testing Alpine w505 Double Din/ Navi
  58. 05 bought without nav, custom installed gps
  59. Help with audio... =D thanks
  60. easiest way to get to the passenger door speaker?
  61. Factory Navigation w/ Aftermarket Head Unit
  62. Where to Buy...PXAMG
  63. swapping an 04 g coupe bose into an 03
  64. 06 Coupe Amp install.
  65. Pac aai-nis2 ??!!
  66. Pioneer F900 BT-Speaker Issues
  67. which is better for my headunit? 2way or 3way xover?
  68. avn5510 need upgrade nav disc
  69. OEM navigation - ?s about maintenance screens
  70. ECM Question
  71. fuses
  72. 03 g coupe no sound from radio
  73. laptop mount
  74. So tried the PAC AAI-NIS2...to no avail...
  75. Satelite radio question... VIN doesn't match prewire, but has SAT button? (03 MY)
  76. Need feedback on Eclipse AVN4430
  77. DNX7120 / DNX8120 Newb Questions!
  78. Optima or Stinger Battery?
  79. How to wire a Zapco Reference 500.1 directly?
  80. pre-wire harness ???????
  81. Need help/advice with speakers
  82. Is this aftermarket set-up ok? (Speakers/Subs/HU w/ DD Metra Kit)
  83. ipod Factory Integration ??????
  84. pxamg not working after battery disconnect
  85. 2003 g35 coupe pre-wired?
  86. Pac TR-7
  87. HELP! sub works speakers dont
  88. Need new OEM radio
  89. 03 G coupe.. that is not prewired for XM/Siri.. what do I do?
  90. Ipod Adapters
  91. ZEnclosure Issues
  92. How can you tell if a g35 coupe has XM radio option?
  93. 4080 enlosure for 2005 G35
  94. ok 1 wierd question. help out please
  95. a couple questions, hope you can help!!!
  96. Ipod install no longer works
  97. 04 G35 Bose Radio acting really weird
  98. Parrot bluetooth kit install problem
  99. Help, need the main wiring harness
  100. 05 bose HU wont play cd-r or mp3's
