- Reflector housing mod to fit projector 06
- Intermittent headlight
- 06 tail lights on 05 g35 coupe
- Headlight issues
- Help 06 G35x reverse lights not working
- Headlights HELP PLEASE
- recommendation for H1 hid kit
- Retrofit 350z projectors into sedan housing?
- drl wiring question
- Trading my 05' headlights + $300 for 06' Projectors and 5000k bulbs a good deal?
- Which headlights does my car have?
- 03 Smoked Taillights
- g35 Demon Eyes?
- Aftermarket headlights
- interior and exterior make over
- Diode Dynamic HID Kit - 06 Projector - Fog Upgrade
- 06 Projector Headlight - Upgraded HID kit
- Analog Clock Repair
- Lights under the door
- 06 g35 coupe
- Healight mods question
- Are all d2r xenon bulbs d2c?
- Orange turn signal light out
- Odometer no longer lit
- hid vs halogen housing???
- Lense replacement.
- Tachometer orange light changable?
- 3rd Brake Light/ CHMSL repair parts?
- Glovebox light won't turn off!?
- 05 6MT Rear Camera in wing install advice needed.
- Driver Side Headlight Help.
- Projector color cutoff mod..
- Strip bulb in coupe headlight
- Philips HID seller : Reliable?? Pls Help..
- side marker clips, noob question
- 06-07 projectors help?
- Projector Demon Eye Wiring Problems
- Are these JDM taillights?
- Missing door courtesy light (Under Door) and Trunk Light
- Interior lights
- Turn Signal Issue
- Tail lights rewired to a button...
- Auto Shifter Position Lights won't work
- Upgrading Headlights - Need opinion
- Those with oem projector lense moved to turn signal spot
- screeching from brake.
- Cheapest phillip 6k d2s bulbs?
- Trunk Cargo light replacement?
- CCFL Clearance retrofit
- Are these stock 4300k g35 projector headlight bulbs?
- Tail light fuse keeps blowing
- How to pop out license plate light housing?
- Passanger Side Blinker... HELP!
- HID on/off
- help and advice needed!
- About to mod my headlight soon, need input
- Dome light/Step lights went out
- headlight fitment
- Reverse LED Bulb
- Driver side low beam not working
- LED turn signals
- PIAA HID kits
- Ambient LED Install Pictures!
- 2004 G35x sedan left LED brake light out
- Spyder Auto Projectors Detailed Review
- Parking Brake Light Fades in HELP
- Passenger Headlight flickering
- Need help with wiring please
- Halo Headlights
- 350gt Coupe headlights the same as 350gt sedan?
- Ceramic H4 Heavy Duty Wire Harness
- Blacked out ebay lights with hid
- 03 hid kit help?
- H4 LED Fog/high bulb
- Need help with my high/fog lights......
- Need help with wiring pls
- *The Official Retrofit/Painted Headlights Picture Thread*
- replacing 06 g35 coupe headlights. help appreciated
- Help.. Ok my headlight doesn't work unless I switch them to high beams.
- Projector Retrofit - 04 Coupe
- Question about my 05 G35 headlights
- One DRL headlight out
- CCFL Clearance Strip Retrofit DIY??
- CCFL strips for DRL on 06 projectors
- Custom Headlights question
- driver side headlamp stopped working
- Custom Gauge Cluster
- can a Corroded battery cable cause headlights to fail?
- 3rd Brake Light Tip
- Low beam retrofit - comments/idea/thoughts
- Quad reto fit parts list
- HEADLIGHT ISSUE H/L. Help!
- Replacing Stock Low Beam/HID Fogs
- Headlight housing
- Headlight question
- Ghost Shadlow Lights Flickering Problem
- Planning retrofit - 2003 G35 sedan
- Headlight questions
- Instrument Gauges Lighting Goes Off..On..
- Aftermarket Headlights
