- Wheel locks
- Advice needed
- Tell me what you think :)
- Brake Recommendation for G35X
- G35X w/ eibach prokit + 19x9.5 +22 all around?
- Please help on suspension choice
- place to buy rack and pinion for g35S
- H&R DRM spacers
- Need fitment help!
- Front and Rear sway bar install question
- Tanabe Sustec Pro S0C Rear Adjustment Help
- Trying to find ball joints and tie rods
- Infiniti Dealership Disable TPS System?
- Sport brakes on an X
- Can't decide on rims :(
- Another Lowering Spring Install DIY with pics - 2007 G35x Sedan AWD
- Clicking/grinding rear differential noise
- Wheel sizing
- I'm about to pull the trigger on new rotors/pads from performancebrakes.com
- G35s/G37s Sedan Suspension on G35x
- Brake Rotor Question
- WTB 07 g35s lip
- 19" wheels Stock suspension 07 G35s sedan
- G37x or G37xS coupe struts - for G35x sedan?
- Akebono Upgrade Banjo Bolts
- RE: Springs?
- Alignment results... what's wrong here?
- two questions
- 20x8.5 +30f on 245/35 and 20x10 +38r on 275/30
- Whiteline Rear Swaybar Question
- G35X brakes on fire
- Struts and Shocks with Lowering Spring
- Koni Sport (yellow) shocks - soon I hope!
- G35 rwd vs awd: same wheels clearance?
- Sway Bar Link Warranty Question
- CV Boot Missing
- Problem with tram-lining (road following)
- OEM lug nut size?
- Hotchkis G35X Sway bar with Stock Springs
- Does anyone have pictures of blacked out G37 rims?
- Tire Size question!!!
- Got Goodridge Brake lines!
- Recommendations - Pads and Rotors
- Tire recommendations for 07 G35 sedan sport
- suspension compatibility with other cars
- Brake Judder TSB splash shield
- 18" Stock Sport Wheels... Spacers Brand/Size?
- Eibach Pro-kit squeaks
- X and rwd sedans wheels offset?
- Brake upgrade please help!
- Lowering a 2008 G35S Sedan
- Recommendations for Five Spoke Wheel
- G35X Sway Bar Upgrade
- motion ratios
- Concave Wheels
- pls help with coils
- 20x10 + 35
- anyone with g37 coupe H and R's on their 2nd gen sedan?
- which tires to get?
- Does someone use 275/40/18 on stock S wheels?
- 255-40 18 on sport rims?
- Need ANOTHER brake job-HELP!
- Rear Shocks
- Noise from Blizzaks or wheel bearings???
- ordering stuff in prep for going home
- Parking brake pads kit?
- Wheel bearing?
- Pads and Rotors Help
- recommendation for pad on X, OEM rotor
- Tire Sizing for aggressive 20's with Eibach drop
- Aggressive offsets EyE CandY :D pics
- Michelin Primacy MXV4 - Review
- H&R Coil over
- Where do you get your Rotors and Brake Pads?
- New TSB for front brakes!!! ITB11-050
- 07 G35 Sport Sedan Brake Questions
- 225 rear tires for winter setup?
- Brake pads for track and street
- Dropping G35 '07 on 20"s.. advice on COILOVERS pls
- Eibach Springs w/ non Sport Journey Struts/Shocks
- who makes a front camber kit for 2008 g35x
- Wheel, TIre and Suspension Advice
- if u have tein super street .. chime in
- Service life of OEM struts
- Is This ok to use as Brake Grease?
- Folks, do these sizes look ok to you?
- br type Coilover,anybody have tips on installing and adjusting them.
- Anyone tried B&G S2 Sport Springs?
- Do my pads need replacement (Pic)
- Stock G35x wheel well height?
- New Guy
- Would they fit?
- Installed Eibach Pro-Kit & Sways (Not happy)
- Stock Brake Pad Shims?
- Staggered sport wheels, different tire sizes?
- Coilover Adjustments (BC Racing)
- Pics request for sedans on 20mm or 25mm spacers
- lowering 04 coupe
- Stoptech Street Performance Brake Pads – Review
- 2008 G35XS Rotors
