PDA
View Full Version : V36 Brakes, Suspension, Wheels & Tires
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20
  1. What is the point of all-season tires?
  2. Akebono vs Stock brake weight
  3. Do Koni Yellows fit 2nd gen sedans?
  4. Akebono brakes fit 2007 G35S Sedan
  5. Will they fit to G37 coupe?
  6. Staggerd on G37X question....Can i run this?
  7. Searching ...and searching... for a durable aftermarket all-season 19" WHEEL
  8. Review of the Akebono set-up
  9. Impul springs for my X, which one do i need?
  10. Impul springs for my X, which one do i need?
  11. help Brake rotors upgrade
  12. New to the community - Bought an 08 G35X need tires feedback
  13. OEM Brake Pads
  14. Impact wrench question
  15. Some news on aftermarket struts
  16. Alll weather Tires for Infiniti G35X
  17. Alignment issue
  18. Suspension squeaking over speed bumps
  19. Question about jack points
  20. Are these sizes ok?
  21. lug nut specs?
  22. Stock brakes suck, what are my options?
  23. Perfect G37X sedan springs. Am I crazy?
  24. new Hawks HPS brakes making a squeek
  25. new tire suggestions?
  26. Disabling TPMS
  27. Tire Terminology and choices for next spring
  28. Will G37 journey rotors fit my G35 sport?
  29. wheel replacement?
  30. 18's: anyone try to put the rear size on front?
  31. Tires sensors and rims
  32. Akibono BBK Stock G35S Wheels
  33. Which Tire would you go for?
  34. Tire Maintenance light plus more
  35. Stock brakes on front Hawks on back??
  36. Replacing the Goodyear Eagle RSA's
  37. Should I use the FX35 rims?
  38. Wheels/Tires
  39. Hardware for new wheels (nuts, rinngs)
  40. BC Racing vs KW Coilovers
  41. Need help finding valve stem, Please!
  42. Lowering Springs and Camber Kit Combo
  43. JIC VIP Coilovers
  44. brake pad replacements
  45. Review: Tanabe Sustec Pro S-OC Coilovers
  46. Help Guyzz! Noise
  47. Installed the Akebono brakes - finally
  48. 18x7.5 et38 w/ Stock "S" Sizing: Rub if Lowered?
  49. DIY Brakes
  50. How are these for track wheels/tires?
  51. Question on Offset and Fitment
  52. Are +20 offset 8.5 or 9.5 wide wheels too aggressive on a sedan?
  53. Alternate sizes for G35S tires
  54. Do you run snows on your G35X?
  55. what tires are the oem '09 g37x sport 18s?
  56. Snow tire help needed
  57. Suspension / Alignment experts, come on in
  58. 350z Rims
  59. Obsidian Black with Black G37 Coupe S Wheels
  60. Help,Will 2003-5 G35 17 inch wheels fit 2009 G37x
  61. Toyo Proxes 4 on OEM Sport Rims
  62. 2008 Maxima/Altima Wheels for an 07G35x
  63. 07 G35s tire questions
  64. after coilover installed
  65. Tire Debacle
  66. Need help with tires
  67. Need help in camber settings
  68. 255/40ZR19 & 285/35ZR19s....
  69. Random comment on Falken FK-452's
  70. Why are my inside front tires bald? *Pics*
  71. coil over decision
  72. Best places to buy brake pads?
  73. GTSpec - Revised M, 6point & rear tie installed.
  74. Allignment Done after Eibach's
  75. Need a alignment?
  76. 370Z Sport Rays Wheels
  77. Shudder at 40mph (~60km/h)
  78. Tein Hi-Tech springs
  79. G 37 Coupe wheels for my X
  80. 2007 G35 Brake Noise
  81. Anyone put wider tires on stock G35S rims
  82. New Tire Option
  83. Ichiba Wheel Spacer Question
  84. Can i do all 20 X 10 +35mm on the X?
  85. 04 G35x sedan would 22" rims fit
  86. Alignment specs for 09 G37 sedan non sport
  87. Question about offset
  88. Question about Brakes online
  89. question about brake calipers
  90. which one would look better?
  91. SPC or SPL/Eibach rear camber arms?
  92. 08 non sport brakes vs 09 non sport
  93. Lowering Kits
  94. Cleaning Drilled/Slotted Rotors
  95. Porsche wheels on a 2009 G37 Sedan?
  96. H&R needs to get their numbers straight
  97. 350 z rims on sedan ??
  98. Replacing front tires only
  99. acceleration/electrical issue
  100. Hotchkis sway bar setting
