- anyone with sport 18's want to swap?
- Tanabe NF210
- Putting 19" Maya wheels from my IS350 onto my G. Tire sizes??
- So what's this I hear about aftermarket Springs?
- Hub centric ring
- spring question
- Looking for a decent wheel refinishing shop!
- TPMS Blinking
- Blue collar suspension write up! Tokico blues installed!
- What do you think about this size???
- when to get alignment after drop
- Fellow wheel/tire experts...
- Bc racing coilovers
- 19" Rim Question
- After a couple days on H&R's
- Wheel Sizes.......will this fit? Kind of aggressive
- ALL Lowered AWD people - Need alignment help
- TPMS light suddenly gone
- 07-09 X BC Coils tapping sounds
- Will this Wilwood kit fit my X 08'?
- Just Put H&R's on My X
- New pads an Rotors
- Good place to buy shocks?
- BC Coilovers on an X
- Looking for rotors, two size come up for non-sports
- How much can i expect to spend on a nice set of brakes?
- allignment and brakes
- Need Help Nood at rims set up
- Drop in Progress
- 40k miles - just swap brake pads or is more required?
- Sizing/offset help please
- 20" Set-Up ! Help me out !
- Need help for offset and tyre
- a few suspension questions
- caliper swap?
- what springs do i have?
- Spacer recommendation needed!
- Rim/tire combo??
- Eibach Prokit 07+ Sedans
- Will rub or not....that is the question
- Torn lower shock bushing
- proper offset for g35x
- Akebonos
- Just put on 2006 m35 sport rims on my g35x, tpms problems...
- Wheel load ratings.
- KYB Struts/Shocks for G35x
- adjusting height... Need Alignment?
- Stock rim replacement for G35S Sedan
- what offset?
- Recommended shop in SoCal for suspension work
- I am running out of ideas of what my vibrations are caused by on highway
- Concave wheel Offset? XS dropped on Eibach's.. Need Help
- Would you switch them!!
- 245/40/19 or 245/35/19 on 9,5" ET25 G35x sedan
- Wheel spacer recomendation
- Question about wheel spacers
- Does IS350 suspension fit in an 2008 G35 sedan journey?
- No brake pad change DIY??
- Recommended Tires for '08 G35X
- 350Z suspension on a 08 G35
- Drop Spring Opinion
- Lowering an 2007 G35x
- Feeler: 18" G37 wheels
- No offset clue
- Tire Replacement 2008 G35 Sport
- Tire size recommendations?
- Brembo Brake Replacements for only $198
- anyone try 245/40/20's?
- How to repair these rim deep scratches?
- coilover fitment
- Thoughts on 19x8.5 et41 and 19x9.5 et49?
- Struts for My G35X
- 19" Rays Engineering Wheels for 2008 G35 Sedan
- Will G37 coupe 19s on my G35 with OE 18s look...
- What tire pressure should my tires be at?
- g37 coilovers question
- offsets
- install tanabe springs, problems in my garage
- Tire Review: Continental Extreme Contact DWS
- Decisions Decisions...20x9 +25 or 20x9.5 +30??
- New rims
- 2008 Sedan Tein S lowering springs, SPC camber/toe kit maxxed out?
- Has anyone ran 295/30R20 in the rear?
- 19x8.5+34
- 275/35 too wide for M45 sport rims?
- Drop n wheels
- Camber Kit for 2008 G35x on H&R
- My Wheel and tire ?
- Rear sway bar/splash sheilds
- 19x9.5+ 22
- G35(S) Sedan Brakes! S model
- 4WAS + Sway Bars?
- Coil spring spacers?
- Where is good to order rims from?
- Aftermarket wheels/tires and TPMS
- does anyone have megan coils?
- Coupe 05 wheels?
- Eibach Sways - Sharing Pics
- Eibach pro kit ( 6383.140 )
- Stillen vs Hotchkis sway bars?
