- Halo lighting
- Changed factory HID bulbs, also installed HID H4's for the fogs
- Both HID's Out need advice
- HID problem
- DIY Project: Installing the LED Angel Lights on G35 as DRLs
- Are factory HID bulbs 85122 or 85122+ ??
- 4300k vs 6000k
- Can low beam and high beam be aimed separately
- yellow fog lights?
- RS6 Fogs? Have anyone ever looked into these?
- Centering 06 headlights
- What HID headlights do I need for my 2005 coupe?
- 03-04 g35 sedan vs 05 g35 coupe headlights
- How to test tail lights without installing them?
- 03-04 headlights same as 05?
- Front Headlight Question
- HID setup for eBay JDM black halogen headlights.
- Want to install HIDs to match my LEDs
- Cheap G35 Xenon Bulbs?
- Tell you what, this LEDS SUCK!!
- Silicone For Headlights
- Tempertaure gauge goes on and off
- '04 Sedan projector retro question
- Headlights
- Blue Gauges
- something wrong with the auto on/off for headlights
- Clearance Strip Mod
- HID Bulbs
- Will these work for parking/city light LEDs?
- how do you get a sharp cutoff line for projectors?
- are there any LED bulbs for turn signals in the headlamps?
- led bulbs for reverse lights for 06+ coupe tails.
- Reconnecting Door / Courtesy Light
- Thinking about upgrading...
- LED Strip Running Lights / Fog Lights
- Amber leds in stock clock?
- How to get to fog lights
- Crack in headlamp
- Clearcoating headlights?
- Yellow Clearance Strip
- Headlights WTF is this? Pictures in side....
- Ballast Nightmare! No headlights!
- Which fuse is it..?
- G35Coupe Halo Angel eye tail lights...skyline r34 look
- Questions about ballast
- Ballast or bulb? Help please
- Changing Ballast (accesible w/o removing headlight)...
- need some electrical help pls
- skyline style taillight mod
- changing fog lights...
- silly fog light question =x
- Bulb or Ballest
- BLUE 2006 HeadLights?
- PIAA 4400k H1 bulb???
- what a steal!!! and bulb opinions
- Quad Project
- Philips crystalvision 5000k bulbs
- HID's: What you should know before you buy!
- Projector vs. Reflector headlights
- HID headlight help
- 06 headlight conversion
- Interior LED accent lighting?
- 05 reflector and projector mod. need feedback! praise/criticism welcomed
- 2003 Coupe lighting question...please help
- LED bulbs in dash
- looking for some advice on projector retrofit
- H1 bulb or D2R bulbs.
- Help! Interior Trunk Light Fuse/Connection bad
- 3rd brake light problems
- custom led headlight project
- will this bulb work for under the door?
- wetsanding headlights after using 3m headlight restoration
- 06 headlights on 03 G
- HID flickering lamp
- fog bulb lightning
- G35 Retrofit with lots of goodies....
- Sedan 05 headlights to 06
- Spare Tail Lights - How to turn into a DISPLAY?
- Do I have to buy a xenon headlight replacement or just halogen?
- 03 headlights to 06 headlights
- DIY: Change Brake light?
- Does anyone have experience with the Umnitza V2 angel LEDs?
- HELP: Reverse Lights
- KeyLight Handle Turn Signal
- Obsessing over lights
- Clear Corner bulbs
- H.I.D Kit
- Can You replace the 05 Coupe Amber signal bulbs with clear bulbs?
- Upgrade My Low Beams for 03 Coupe
- Anyone ever have problems with vleds lights flashing?
- yellow oxidation on headlight after blacking out
- DIY: Highbeams Flash = Garage Door Opener
- $50 D2S vs. Phillips $200 + ???
- Matching hyper white dual filament blinkers
- blown fuse
- bulb upgrade need link help
- LED wiring help
- Which LEDs should be used for back seat?
- Which led bulbs should I use for my clearance strip?
- Plug in?
