- questions about HFC's
- Transmission issue...
- The thing you all been waiting for....
- Rear shake during acceleration
- Power gains 2007 G35 4dr?!?
- Problem: eractic idle...
- Recently got Car Serviced.(Price Check)
- New 2005 350z clutch in 2007 g35
- axle back exhaust option or straight V clamp pipe
- Upgrading Y and Center pipes G35x Sedan
- Upgraded radiator option for our cars?
- Removed Stock Mufflers
- Bad hesitation
- Will TWM Short Shifter Fit?
- Engine power loss
- Muffler
- P0014
- Takeda Dual SRI
- Cleaning engine bay
- Force Induction system for 2007 sport sedan?
- Stillen G3 CAI, looking for another filters option!
- Z1 vs Berk HFCs
- Triptronic Issue?
- Suggest some muffler tips!
- 09 Tranny in 2nd Gen G??
- DC Sports Intake
- Installed Magnaflow 11385 with stock muffler.
- Muffler or Catback System
- When my long block was replaced..did it get new spark plugs?
- Overbore is necessary?
- HELP! Transmission change
- muffler delete
- Oil/Coolant Mixing Issue
- does the V36:VQ35HR still suffer from the oil in spark plug tube issue?
- FI or Ark Grip with Berk HFCs?
- Low RPM trans slipping?
- Let the modding begin !!!
- Water Sloshing Sound!
- Issues after AWD front wheel hub swap
- Review of Invidia sedan exhaust
- OEM muffler tip inlet size?
- Oil Filter PN update... 9E000 ----> 9E01A ?
- Trying to match the tone of 2005 G35 coupe
- 37x sedan
- New purchase
- Motordyne Intake Manifold M370
- quick question?? diameter of oem exhaust
- Exhaust clearance
- Shifter Stuck In D AGAIN
- Custom Exhaust with Branch Resonators!
- Y-Pipe vs. X-Pipe and Drone
- Getting Exhaust !
- My new Ark Grip :)
- getting rasp with my ARK exhaust
- Fast Intentions
- Filters >> stillen G3.
- Berk high flow cats
- Invidia exhaust buzz
- Different y-pipe for Stillen CBE?
- Ark Grip Exhaust !
- Stillen supercharger
- Weird issue when accelerating
- Video: Muffler delete
- Mishimoto Intake Tubes
- Custom Exhaust
- Engine sounds like a diesel when cold
- Installed my Invidia HFCs... Whistling noise...
- Coolant problems
- Gaskets for Exhaust
- Does the 350z y-pipe fit?
- Megan Resonated TP's
- will this nismo part fit the 08 sedan?
- DYI 14 mm spark plug socket
- Getting driveshaft balanced
- Motor Mounts
- Motordyne Engineering
- 6MT Oil - Amsoil vs. Red Line?
- Remove pedal cluster?
- Stillen VQ35HR Supercharger Kit
- Broken Cam Shaft on 2008
- Kinetix HFC work on G35x
- 6mt oil change..replace washer?
- Which oil to choose? Oil gurus, please, chime in!
- Temp gauge not working at all...please help!!!!
- Dont use synthetic oil?
- g37 intakes fit our cars right?
- G37 Sedan Exhaust.
- ART pipes on AWD
- Car died on the way to work this morning - Jump start? No says I
- Which exhaust there is so many!
- Engine whine
- lightweight flywheel upgrade, clutch, and CSC concentric slave cylinder
- Best exhaust for 2nd gen g35x?
- car feels slow when the tank is full?
- Heat shield
- Thinking of buying Invidia HFC! Any thoughts????
- Random revving at stop and lower mpg
- My first G35! Now.... Questions.....
- Will this Y-pipe fit?
- magnaflow catback, who have it?
