PDA
View Full Version : V36 Engine, Exhaust, Drivetrain & FI
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13
  1. g35 coupe loses power after driving approx 20 min
  2. Getting Vibrant Resonators, what size!?
  3. Slight misfire when cold, fine when warmed up
  4. No compression
  5. 2007 G35X front passenger side noise
  6. 2005 atx to 2007 atx vqde35 tranny swap (tcm reprogram)
  7. hard start rough idle p0345
  8. Custom Exhaust Help :)
  9. 2007 G35S sedan OE exhaust - NE OHIO free
  10. Drivetrain upgrade suggestions?
  11. 07 G35X Jerking while making sharp turns
  12. Throttle Lag
  13. ECM Reflash 2007 G35x Auto - TSB
  14. '07 g35 exhaust questions
  15. Pinging
  16. My first post, and first mod. Had one small hiccup.
  17. Please Advice, Rattling Noise, P0021
  18. Dealer used BG transmission fluid
  19. Oil Sensor Light On When Idle
  20. BEST Y-pipe to match OEM sedan mid pipe-to-Tenabe axle-back??
  21. Driver's side cv axle bolts
  22. Need diagram or scheme cooling system
  23. G35 Wont start after clutch change
  24. Sudden Idle Drop
  25. Intakes...the debate continues.......
  26. 2007 G35 Sedan acceleration off, O2 sensor codes.
  27. Start up issue after mechanic visit
  28. V36 Sedan and 370z compatablity parts
  29. Muffler Delete With Vibrant Resonators??
  30. Help With Choosing Exhaust After Return
  31. Car shifts into reverse, but doesn't move [5AT]
  32. OEM air intakes box filter replacements with Aftermarket air filter pod?
  33. Air fuel ratio (A/F) sensor 1 replaced
  34. What is the mid-pipe intlet size for a 2007 G35x?
  35. Injen Air Intake
  36. Transmission slip when warm
  37. V36 G35X sedan exhaust
  38. Transmission Stutter
  39. Ark exhaust off of g37xs
  40. New owner! 07 G35X, P0024 and P0014 CODES!
  41. Synthetic oil replacement interval
  42. That engine knock!
  43. Transgo shiftkit & P0735
  44. Nitrous on their g35x sedan, Has anyone done it? and bolt-ons
  45. P2a00
  46. Gains from intake systems?
  47. Untrackable idle rattle (with link!)
  48. P0420
  49. AAM Restest on 2008 g35x question
  50. Dealing with P0420
  51. Engine sounds
  52. 05 6MT 6 Gear swap advice needed.
  53. Valve body replacement at 27,000 miles?
  54. Checklist for 07 G35x hesitation at low RPM
  55. Ebay y-pipe broke
  56. Hypermax Sport tuner
  57. Ebay Y-Pipe?
  58. DIY Mass Airflow Sensor Cleaning MAF
  59. smell of coolant coming though vents
  60. Stuck Midpipe Bolts?
  61. Issues with my 2008 G
  62. Spark plug recommendation
  63. Scheduled Service and Information to Know
  64. Transmission fluid leaking into Radiator
  65. Changed Radiator, now A/C doesn't work
  66. Ways to quiet my Ark Grip Exhaust?
  67. Quick G35/G37 exhaust question
  68. Intake Fitment Question
  69. G35X tranny
  70. Are there any Y-pipes are compatible with the RWD S?
  71. Review of TopSpeed Pro-1 G37 Sedan Exhaust
  72. Building a custom exhaust
  73. Aftermarket radiator and condenser help!
  74. 2007 G35 Sedan leaking valve covers..
  75. Cosworth oil pump
  76. Axale Back Muffler or Muffler help
  77. CV boot / axle?
  78. AAM S-line exhaust
  79. High RPM's on Highway
  80. 07 5at to 7at
  81. Exhaust leak, maybe new pipes?
  82. Muffler Delete DIY
  83. Problem with engine i think
  84. Engine making a knocking sound
  85. Whats the best TP to use with stock exhaust
  86. my exhaust story so far...FI/Kinetix/ARK/Tanabe
  87. GTM aluminum driveshaft
  88. Dynojet baseline b4 Uprev 2007 G35S 6MT sdn
  89. Exhaust questions
  90. need help with finding the right parts
  91. Carbon Fiber Driveshaft
  92. How to spruce up these exhausts before mounting?
  93. Contaminated coolant!
  94. Best exhaust for 08 sedan?
  95. PNP throttle body and manifold?
  96. Review: ARK Grip Cat Back Exhaust
  97. VDC / Spinning out question
  98. Where to look for clutch cylinder leak
  99. VDC Off/Slip Light + Hard Shifting (AT)
  100. Whiteline diff bushing install
